Dynam GB-Y prop adapter
  • doctormike
    HobbySquawk Moderator
    • Oct 2013
    • 1260
    • Santa Fe NM
    There is an issue with the prop adapters snapping just from putting the prop on. I wonder if the replacement adapters have been corrected, or if there is an alternative adapter. Doc
  • doctormike
    • Oct 2013
    • 1260
    • Santa Fe NM
    MRC is already taking care of this problem...of course.
    • doctormike
      • Oct 2013
      • 1260
      • Santa Fe NM
      Now... a warning about the Gee Bee Y foam hinges... They will fail! Mine seperated on the second flight. I've repaired the plane and used E-6000 on my hinges. Any good contact cement will work. I'm giving all my foam hinges a coat of this. Doc
      • Dewey H Lee
        WARBIRD JUNKIE
        • Apr 2015
        • 919
        • Fayetteville NC. US
        Hey Doc. I think that all Dynam planes must have this problem. Good plane just thin hinges. Both my Pitts and Hellcat exhibit seperation and I still haven't flown the Hellcat yet. Have used the foam tac on the Pitts to repair the upper and lower wings. I'll take your advice and do the Hellcat before l put her up on maiden.
        Dewey l
          • 8749
          Doc, what exactly on the "adapter" is breaking? Is it the threaded motor shaft or that little cone nut that holds the prop on?
          • Pheonix
            • Aug 2013
            • 670
            On my Dynam planes, I take a thin film of Foam tac and run it the entire length of the hinge using a epoxy stick. This makes a strong hinge. It only takes a little. Let it dry and flex the hinges well afterwards. I have had no issues with from hinges using this method.
            • doctormike
              • Oct 2013
              • 1260
              • Santa Fe NM
              xviper2... The adapter shaft snaps because it is drilled out too deep, into the threaded portion. MRC has notified Dynam of the problem and they are replacing it. Pheonix...Foam tac is good too. Every foam hinge should be reinforced this way. Loss of a plane is one thing... Hitting something or someone with an out of control plane, well...you can only imagine!!! Doc
                • 8749
                Perhaps it's unique to the PB-Y. I don't think there's something similar in my C-47 and Grand Cruiser.
                • Iowa54
                  • Sep 2015
                  • 184
                  Its a Dynam problem, My AT-6 Texan did the same thing. Wasn't much past finger tight and it snapped off.
