MKIII Alpha Strike 900G 620mm (24.4") - PNP from ZOHD - ZOH10069
The MKIII Alpha Strike has a wing body design with an airframe that is molded from EPP and enhanced with carbon fiber, which also features Sharp Airfoil Design. This new MKIII phase of products includes a commitment to higher-end design, putting emphasis on enhanced aerodynamics. Take this FPV-capable craft to new heights and explore the wide flight envelope while enjoying the first class customer support you have come to expect from Motion RC.
Sleek and Aerodynamic Stylings The MKIII Alpha Strike is a clear and concise departure from the older, less aerodynamic profiles expanding the pilot's flight envelope to include aerobatics with ease. |
Detachable Wings Although already a sleek, smaller scale profile, the MKIII Alpha Strike has detachable wings and tail fins for added convenience for transport and storage. |
Molded Hand Launch Grip The MKIII Alpha Strike takes the stress out of hand launches by offering pre-molded hand launch grip points to make your hand tosses comfortable and easy each and every time you fly. |
Generous Space for Battery and FPV Gear The battery bay of the MKIII Alpha Strike is plenty spacious affording ample room for your chosen 4S LiPo battery and any FPV gear you require (not included). |
- A specially-designed servo arm “bunker” structure protects your servo arm from impacts and minimizes drag
- Compatible with most racing quad drones and FPV gear
- EPP molded airframe and built-in carbon fiber spar for enhancement
- Innovative Sharp Airfoil design and aerodynamic airframe
- Detachable wing and tail fins, portable and easy to pack
- Innovative Twin Bay Design: Limitless options for setup
- Teflon skin protection to avoid scratches when landing
- Molded hand grip slots for a worry-free hand launch
- Improved air rolling design to protect your gear
- ZOHD MKIII blended wing body configuration
- Molded marks for “CG” under the wing
- Super stable flying performance
- ZOHD Alpha MKIII Strike 900G 620mm (24.4") - PNP
- 2216-2200Kv brushless motor
- 40A ESC with 5V/3A BEC
- 6x4.5 propeller
- 2x 4.3g servos
- Owner's manual
- 4 Channel radio - select a minimum 4 channel radio from our Radio Collection
- 4 Channel receiver - select a minimum 4 channel receiver from our Receiver Collection
- 4 Cell 14.8V 2200 - 3200 mAh LiPo Battery - we recommend the Admiral 3000mAh 4S 14.8V 35C LiPo Battery with XT60 Connector
- 4 Cell compatible battery charger - select a minimum 4 cell (4S) charger from our Charger Collection
AGE LEVEL :14 and up
SKILL LEVEL :intermediate
BUILD TIME :1 hour
Model Scale | N/A |
Wingspan | 620mm / 24.4in |
Length | 650mm / 25.5in |
Weight | 900g / 31.7oz |
CG (Center of Gravity) | Refer to owner's manual |
Power System | 2216-2200Kv brushless inrunner motor |
Electronic Speed Control | 40A with 5V/3A BEC |
Propeller / EDF | 6x4.5 2-blade |
Servos | 2x 4.3g servos |
Landing Gear | N/A |
Required Battery | 4 Cell 14.8V 2200 - 3200mAh LiPo battery with XT60 Connector (required) |
Required Radio | 4+ Channel (required) |
Ailerons | Elevons |
Elevator | Elevons |
Rudder | No |
Flaps | No |
Lights | No |
Hinge Type | Nylon |
Material | EPP |
Skill Level | Intermediate |
Build Time | 1 Hour |
Recommended Environment | Outdoors |
