Official Skynetic 700mm Dragonfly Seaplane V2 Thread
    • 8228
    Dragonfly Seaplane V2 700mm (27.5") Wingspan from Skynetic - PNP - SKY1046-001
    The Skynetic Dragonfly Seaplane V2 is an all-terrain aircraft capable of takeoffs and landings on water and grass, just about anything with a smooth surface. Capable of impressive speeds due to the powerful brushless motor. The Dragonfly V2 is bound to offer up many hours of excitement and thrills by land or by sea!
    • Made from durable EPO foam
    • Powerful brushless motor delivers impressive speed range
    • Elevated propeller avoids any potential landing damage
    • Capable of multiple takeoff and landing surfaces
    • Skynetic Dragonfly Seaplane V2 700mm (27.5") Wingspan - PNP
    AGE LEVEL: 14 and up
    SKILL LEVEL: Intermediate
    BUILD TIME: 15 minutes
    Model Scale N/A
    Wingspan 700mm / 27.5in
    Length 970mm / 38.1in
    Weight 575g / 20.2oz (w/ battery)
    CG (Center of Gravity) Refer to the manual
    Power System 3S Brushless Outrunner Motor
    Electronic Speed Control 40A
    Propeller / EDF 2-Blade Propeller
    Servos 4x 9g
    Landing Gear None
    Required Battery 3S 11.1V 1500 - 2200mAh LiPo (required)
    Required Radio 4 Channel 2.4GHz (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Hinge Type Nylon Reinforced
    Material EPO Foam
    Skill Level Intermediate
    Build Time 15 Minutes
  • James
    Administrator
    • Aug 2017
    • 1543
    The Dragonfly is back in stock only it now is in a base white scheme with orange trim.
    This one is very fun on the lake!
      Great flying little plane
      • Scott Page
        • Jan 2021
        • 14
        I've been waiting for this to come back in stock and pulled the trigger immediately after seeing the email notification. Our club has a fly on the water every week in warmer months. I'm sure this will become a popular choice once they see mine.
        I prefer the original color scheme. James mentioned how good it showed up in his video and I agree.
        I'm GUESSING the new color scheme is either cheaper to produce, or marginally lighter -- or both.
        I WISH that the photos would show the BOTTOM of the plane -- after all that's the part we look at most of the time when flying. It would be great if this had some big ole' stripes on the bottom of the wing. I'm GUESSING that the bottom of the plane is entirely white which means that it will need some paint.
        Anyway -- I'm anxious to receive this and get it on the Columbia River --- maybe (if the shipping gods are gracious) as early as next Wednesday's float fly.
        • Rickey ouimwt
          • Jul 2023
          • 3
          I ordered a plane from you guys can you tell me when it's going to be delivered
            • 5401
            This is a discussion forum about the plane. Easiest if you either look up your account (usually ships the next working day but you may get shipping info the same day) or if you call them.
            • ElazulRC
              • Jul 2023
              Has anyone installed a GYRO on this Skynetic DragonFly? If so, which GYRO and any gotcha's?
              • bd4rc
                • Sep 2023
                I just got mine, planning on putting a RadioLink Byme-A Gyro in it this week, will report back. I also put in a Freewing v2 reversing ESC, putting the reversing channel directly to an ELRS receiver with SBUS going in to the Byme-A and all servos going out of Byme-A. I am not sure how the gyro will respond to reverse thrust, may need to put it in manual mode for that, but that should be fine for taxing in the water at least.
                I'm also curious to know other people's gyro experiences.
                • bd4rc
                  • Sep 2023
                  Works great with the Byme-A Gyro and a Radiomaster ER4 expresslrs PWM receiver configured in SBUS mode. Actually surprisingly easy to fly, easy to land and take off in both grass and water. Probably would not recommend as a first plane, but maybe a second plane with a gyro installed. It does take longer to take off than a high wing trainer, but is not unreasonable take off distance.
                  • Glazer
                    • Jan 2021
                    I assume the supplied balloon is for ballast...can someone explain how it should be used?
                    • Sureshot
                      • 235
                      The receiver goes inside the balloon to keep it dry.
                      • jetman#1
                        • Dec 2023
                        the model you have on stock is the old version the v2 is orange!
                        • Ks4sa
                          • May 2018
                          • 11
                          Anyone know the motor kv for the dragonfly 700mm
                          • Nitehawk386
                            • Mar 2024
                            There isn't a lot of activity lately on this forum. Has the Dragonfly been out of stock for some time? Is there any idea when it will be back in stock or should I look at the Skipper?
                            • Rosco
                              • Aug 2024
                              Love the Dragon Fly V2, but after several flights had to remove engine and epoxie the firewall to foam back… the engine was VERY loose.
                              • Rosco
                                • Aug 2024
                                I installed a Spektrum AR631 receiver with AS3X… works great.
                                • SukhoiEli
                                  • Oct 2024
                                  just got my new dragonfly, do you know where the little 1 pin plug beside the throttle plug goes on the AR631?
                                    • 5401
                                    Reverse? Easiest is the ch5 retract slot.
                                    • Gopherboy6956
                                      • Jul 2025
                                      Hey all - just got my dragonfly. Assembeled it, then hooked up my spektrum AR8020T - everything works, but no throttle and I get a constant beeping out of the motor. All wires appear to be connected. Any ideas?
                                        • 8814
                                        "Appear to be connected"!!??
                                        Check following:
                                        1. Check that the throttle lead isn't backwards - ie signal to signal, ground to ground. Actually check them all.
                                        2. Lower throttle trim to lowest, then bind. Then do throttle calibration. Adjust throttle cut level accordingly.
