Official XK Model 320mm A180 F-22 with Gyro Thread
  • Official XK Model 320mm A180 F-22 with Gyro Thread
    A180 F-22 with Gyro 320mm (12.5") Wingspan from XK Model - (Ready-To-Fly) - RTF - WLT-A180
    The XK Model A180 F-22 RTF is a great introductory jet model aircraft for beginners due to its built-in stability system (3D/6G) that supports smooth flights and resistance to crashes.
    The powerful brushed motor supports a wide flight envelope for flying everything from stable flight to impressive aerobatics. The XK Model A180 F-22 boasts attractive scale looks in a grey camo military scheme and comes with LED lights for nighttime adventures. If you are looking to get into the hobby with a smaller jet with a built-in gyro for stability and nice scale looks the XK Model A180 F-22 would be a terrific choice.
    • Comes with 3D/6G, a gyro for increased stability and helps decrease the chance of a crash. Simply cycle between 6G (stable mode) and 3D (no control surface limits) by pressing the aileron stick to the lower left after activating the model
    • Made of EPP material, lightweight, high flexibility and crash-resistant
    • Compact size and nice scale looks appeals to both novice and advanced pilots
    • Powerful brushed motor supports a wide flight envelope from stable to aerobatic flight
    • LED lights for dusk/dawn flights
    • XK Model A180 F-22 with Gyro 320mm (12.5") Wingspan - RTF
    • FTR Futaba S-FHSS Compatible 4CH 2.4GHz Transmitter
    • 2.4GHz Receiver
    • 2S 7.4V 300mAh LiPo Battery
    • 2S LiPo Battery Charger
    • USB Charging Cable
    • Replacement Propeller
    • Owner's Manual
    Requires:
    HELPFUL TIP: If you are new to radio control (RC) we recommend that you read through our RC resource known as our "Knowledge Blog". It's jam packed with helpful information for beginners including how to articles, support videos, a glossary of terms and much more. Click Here to go to our Knowledge Blog's Beginner Section. For further assistance, please do not hesitate to contact our Customer Support Team and one of our knowledgeable RC experts will be glad to assist you. Happy flying!
    Product Specifications:
    AGE LEVEL:14 and up
    SKILL LEVEL: Beginner
    BUILD TIME: None
    Model Scale N/A
    Wingspan 320mm / 12.5in
    Length 452mm / 17.7in
    Weight 80g / 2.82oz
    CG (Center of Gravity) Refer to the manual
    Power System Brushed motor (included)
    Electronic Speed Control N/A (included)
    Propeller / EDF Pusher propeller (included)
    Servos Micro
    Landing Gear Fixed (included)
    Required Battery 2 Cell 7.4V 300mAh LiPo battery (included)
    Radio 2.4GHz (included)
    Ailerons No
    Elevator Yes
    Rudder No
    Flaps No
    Lights Yes
    Hinge Type Nylon
    Material EPP Foam
    Skill Level Beginner
    Build Time None
