Ressurecting a crashed 1700mm P-47 WIP
  • TSHobbies
    Hobby Squawk Warbird Pilot
    • Nov 2015
    • 671
    • Cartersville GA
    I acquired one of these in a trade a few weeks ago. It was obviously in a bad crash...or a pissed off wife. The fuselage was cracked on one side,and wrinkled up on the other, which, you may notice the bend towards the tail end. So far Ive managed to get the bend out as best I could..looks pretty straight now.
    www.TSHobbies.com
  • TSHobbies
    • Nov 2015
    • 671
    • Cartersville GA
    Heres the fuse straighten out ..also have a couple of questions...
    #1 heres a photo of one of the flap servos...should it be sticking out like it is? or should it be flush with the wing surface?
    #2 does the tail wheel look right? not know what the whole assembly is suppose to look like,just want to make sure...not sure what that one arm by itself is for.
    www.TSHobbies.com
      Hello TS,
      #1 The servo is normally flush
      #2 Tail wheel looks normal but the arm on the servo is incorrect being 90 degrees to the left. It should be centered, pointed directly back at the tailgear strut. I would be inclined to believe that possibly the servo gears have been stripped. That arm is what steers the rear strut when it is extended down.
      Best regards,
      • TSHobbies
        • Nov 2015
        • 671
        • Cartersville GA
        ok thankyou..I'll try and pull the servo trays out, they all seem to be sticking out like that. and the arm I turned with my finger ...you know how it is..whats this for? roll in Fire Marshal Bill...
        www.TSHobbies.com
        • TSHobbies
          • Nov 2015
          • 671
          • Cartersville GA
          Im probably going to replace these servos..any recommendations?
          www.TSHobbies.com
            Parts for that bird are still available, here's the Motion link.
            The servo doing the tail wheel steering is the 25g metal gear one.
            If your retracts are questionable I would upgrade to the all metal.
            • TSHobbies
              • Nov 2015
              • 671
              • Cartersville GA
              well, yes, I know parts are available, Ive read the ones that come with it werent very good,so was asking for recommendations on replacements.
              www.TSHobbies.com
              • TSHobbies
                • Nov 2015
                • 671
                • Cartersville GA
                heres the livery Ive decided to go with..that is, if Callie has it..we'll find out soon.
                www.TSHobbies.com
                • TSHobbies
                  • Nov 2015
                  • 671
                  • Cartersville GA
                  No go on the Dixie Darling,...the noseart they had wasnt quite what I wanted..so now Im going with Busty Angel II
                  got my Beacon filler on the way from Motion, along with the spare parts I needed..so hopefully this project will get going a little quicker.
                  www.TSHobbies.com
                  • TSHobbies
                    • Nov 2015
                    • 671
                    • Cartersville GA
                    got all my spare parts I needed from Motion ,along with a jar of the Beacon foam finish...got one coat of it on the plane so far..filling in all the panel lines as well as the fixed damaged areas. the 8oz jar is almost gone, so had to order a second one to do the second coat. does this stuff not dry hard? I put it on last night, and its still rather soft, which will make it impossible to sand smooth.
                    www.TSHobbies.com
                    • TSHobbies
                      • Nov 2015
                      • 671
                      • Cartersville GA
                      sure wish I had read the reviews on this Beacon crap...sounds like others have the same result...drys to a Elmers glue hardness...now Ive got an entire 1700mm size plane that I have to go back and peel all this crap off.
                      www.TSHobbies.com
