Official Skynetic Mini C185 550mm RTF Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Mini C185 550mm (21.6") Wingspan - RTF from Skynetic - SKY1051-001
    The Skynetic Mini C185 delivers hours of flying fun in a low-cost high-value package. Easy assembly, simple maintenance, and convenient transport are hallmarks of the Skynetic Mini series of aircraft, in addition to arriving Ready To Fly ("RTF"). Simply add AA batteries to the radio transmitter, assemble the aircraft and follow the provided basic setup guide including charging the provided battery with the provided charger, and you'll be flying in no time!
    The Skynetic Mini series of parkflyer aircraft are ideally sized for flying within areas the size of a small soccer field. All RTF aircraft feature built-in gyro stabilization, which helps to stabilize the aircraft in different flight modes to suit your preference. All Skynetic Mini aircraft are supported by a wide range of spare parts and by Motion RC's world-class customer service.
    • Ready To Fly (RTF)
    • Built-in Pre-Programmed Gyro Stabilization System
    • Perfect for beginners or for flying within smaller RC flying fields
    • Durable EPO foam
    • Lightweight, low-mass structure improves durability in crashes
    • Low-Cost spare parts and easy to repair
    • Skynetic Mini C185 with Gyro 550mm (21.6") Wingspan - RTF
    • 4CH 2.4Ghz Radio Transmitter
    • 2.4Ghz Receiver (pre-installed)
    • 6-Axis Gyro System (pre-installed)
    • 1s 3.7V 500mAh LiPo
    • USB Charging Cable
    • Owner's Manual
    Requires:
    HELPFUL TIP: If you are new to radio control (RC) we recommend that you read through our RC resource known as our "Knowledge Blog". It's jam packed with helpful information for beginners including how to articles, support videos, a glossary of terms and much more. Click Here to go to our Knowledge Blog's Beginner Section. For further assistance, please do not hesitate to contact our Customer Support Team and one of our knowledgeable RC experts will be glad to assist you. Happy flying!
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Beginner
    BUILD TIME : Less Than 1 Hour
    Model Scale 1/20
    Wingspan 550mm / 21.6in
    Length 396mm / 15.6in/p>
    Weight 250g
    CG (Center of Gravity) Refer to the owner's manual
    Power System 1020 Coreless Motor
    Electronic Speed Control Integrated
    Propeller / EDF 2-Blade Electric Propeller
    Servos 2x 1.3 digital
    Landing Gear Fixed
    Required Battery 1S 3.7V 500mAh LiPo (included)
    Required Radio 2.4GHz (included)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Hinge Type Foam
    Material EPO Foam
    Skill Level Beginner
    Build Time Less than 1 hour
  • tab28682
    RC addict
    • 338
    • Fort Worth, TX
    This is actually a micro I would buy if there was an option to buy it without the TX and RX. I hate having toy level TX units pile up around the house. Wasteful to buy the whole thing and then throw away the TX.
    The panel lines in the foam are unusually garish, but there are so many great color schemes for Cessna 185 it would still be fun to do one.
