Official 1230mm Skynetic Starling PNP Thread
  • Official 1230mm Skynetic Starling PNP Thread
    Starling 1230mm (48.4") Wingspan - PNP from Skynetic - SKY1028-002
    The Skynetic Starling is a high wing trainer that provides an economical entry for new RC pilots learning how to fly. Made with lightweight yet durable EPO foam with a high cambered wing and rugged tricycle style landing gear, the Starling delivers high value in a low cost trainer airplane. Both the wing and landing gear are easily removable for transport, and the internal structure is sensibly reinforced in specific areas so that the overall aircraft remains both durable and easy to repair.
    Intermediate pilots may choose to remove the landing gear entirely to convert the model to a hand-launch/belly-land airplane for increased speed and agility.
    • Durable EPO foam construction
    • High wing with large camber to increase trainer-friendly flight behavior
    • Rugged and strong tricycle landing gear for added insurance on takeoffs and landings
    • Easy to remove wing and horizontal stabilizer makes transport a breeze
    • Convenient assembly with only six screws
    • Skynetic Starling 1230mm (48.4") Wingspan - PNP
    • Servos, ESC and motor pre-installed
    Requires:
    • 4 Channel radio - select a minimum 4 channel radio from our Radio Collection
    • 4 Channel receiver - select a minimum 4 channel receiver from our Receiver Collection
    • 3 Cell 11.1V 1500 - 2200 mAh LiPo battery with XT60 connector - we recommend EPR18003X6
    • 3 Cell compatible battery charger - select a minimum 3 cell (3S) charger from our Charger Collection
    Product Specifications:
    AGE LEVEL :10 and up
    SKILL LEVEL :Beginner
    BUILD TIME :1 Hour
    Model Scale N/A
    Wingspan 1230mm / 48.42in
    Length 980mm / 38.5in
    Empty Weight 920g
    CG (Center of Gravity) Refer to the owner's manual
    Power System AS2216 Brushless Outrunner Motor (included)
    Electronic Speed Control 30A with XT60 connector (included)
    Propeller / EDF Electric (included)
    Servos
    • 4x 8g micro servos
    Landing Gear Tri-gear fixed
    Required Battery 3 Cell 11.1V 1500 -2200 mAh LiPo battery with XT60 connector (required)
    Required Radio 4 Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Hinge Type Foam
    Material EPO Foam
    Skill Level Beginner
    Build Time 1 Hour
