Freezing 64mm F-16
  • Freezing 64mm F-16
    Anyone know if the Freewing 64mm F-16 PNP should be setup with flaperons or elevons?
    I can't answer your question but I just had to come see what an F-16sicle looked like.
    OK, maybe I can give an answer. It appears that the ailerons and elevators are linked together and it says in the webpage that you can elect to program it as "delta" wing. In other words, set the model as "delta" in the TX and plug each aileron/elevator servo into their respective ports and by trial and error, they should work like "elevons". Each side will UP together and DOWN together when "AIL" stick is used. When ELE UP is used, ALL surfaces go UP. When DOWN ELE is used, ALL surfaces go DOWN. You would not have "flaperons" in the conventional sense.
    Reverse thrust is going to be a really neat feature.​​​
      Elevon setup is required in the transmitter.
        Thats one cold jet
