Official Black Horse Extra 300 2260mm Discussion Thread
  • jbaartz
    • Sep 2020
    • 481
    Extra 300 2260mm (89") Wingspan from Black Horse - Balsa Wood ARF - BHM1009-001
    Click image for larger version  Name:	extra-300.jpg Views:	0 Size:	63.2 KB ID:	350955
    The Black Horse Extra 300 is a large, high performance aerobatic ARF. Constructed from balsa, plywood, fiberglass, and using carbon fiber and aluminum, this Extra 300 sports a large 2260mm (89") wingspan and the versatility to mount either a gas engine or an electric powerplant. Geared toward intermediate to advanced pilots, the Black Horse Extra 300 is a high performance airplane that truly stands out from the crowd.
    High Performance
    With a low wing-loading of 91.8g/dm2 and capable of mounting powerplants up to 76cc (gas) or 6.5kW (electric), the Black Horse Extra 300 delivers high performance in a high quality platform.
    Genuine Oracover
    The entire aircraft arrives professionally covered in genuine Oracover. Trusted for generations, Oracover provides a durable, fuel-proof, vibrant, and lightweight covering.
    Simple Assembly
    Removable wings and easy-to-access compartments for electronics and powerplant make the Black Horse Extra 300 a convenient "daily flyer".
    Durable Landing Gear
    Carbon fiber main gear and aluminum tail gear provide the best balance between weight, strength, and durability.
    Versatile Power Options
    The Black Horse Extra 300 is capable of mounting either a gas engine powerplant up to 70cc-76cc, or an equivalent 12s electric brushless power system of 5000-6500 watts.
    Spare Parts Support
    Keep flying with Motion RC's world-renowned service and spare parts support.
    • Lightweight, strong, laser cut balsa and plywood construction
    • Professionally covered with genuine Oracover
    • Carbon fiber main landing gear and aluminum tail gear
    • High quality control hardware
    • Black Horse Extra 300 2260mm (89") Wingspan - ARF
    Requires (Electric):Requires (Gas):
    • Engine: 76cc
    • Gas Propeller: 22x8
    Customer Note
    Black Horse ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine).
    Product Specifications:
    AGE LEVEL :18 and up
    SKILL LEVEL :Advanced
    BUILD TIME :10+ hours
    Model Scale 1:3.5 Scale
    Wingspan 2260mm / 89in
    Length 2250mm / 88.5in
    Weight 8500g / 18.7lbs
    CG (Center of Gravity) 143mm from the leading edge of the wing at the root
    Power System 180Kv Brushless Outrunner Motor or 60cc 2 or 4-stroke (required)
    Electronic Speed Control HV 120A (required for electric)
    Propeller / EDF 22x12 for electric, 22x8 for gas (required)
    Servos
    • Electric - 6x 45g standard (required) - we recommend HRC32645S
    • Gas - 7x 45g standard (required) - we recommend HRC32645S
    Landing Gear Fixed
    Required Battery TWO 6 Cell 22.2V 6000 mAh LiPo Batteries with EC5 connector in series (required for electric)
    Required Radio 6+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Hinge Type Nylon Heavy Duty pin hinges
    Material Balsa and plywood
    Skill Level Advanced
    Build Time 10+ Hours
  • Bradywatt23
    • Jul 2022
    Nice to see Motion and Black Horse getting into the giant scale 3D market but recommending that particular servo for an airplane like this is asking for trouble. 133oz-in is not even close to sufficient for this size and type of airplane. There will be severe blowback with any large deflections but what people don’t think about is that even if sport flying, the risk of flutter with these large surfaces and low torque servos is very high. The generally accepted torque requirement for planes this size is approximately 400 oz-in. You can get by with less but you will likely have some blowback in any high energy maneuvers. YMMV but I would absolutely not use that servo in a plane like this.
    • Bradywatt23
      • Jul 2022
      I would also like to see some interior pics as well!
