Official Nexa Dornier Do 27 1620mm ARF Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
Name:	nexa-dornier-do-27-army-version-1620mm-63-wingspan-arf-motion-rc-28365484523705.jpg
    The Dornier Do 27 is a German single-engine STOL utility aircraft that was designed and manufactured by Dornier GmbH (later DASA Dornier and Fairchild-Dornier). It was notable for being the first mass-produced aircraft in Germany following the end of the Second World War.
    The Dornier Do 27 is a electric or gas .46-size aerobatic airplane with a 1620mm wingspan, constructed primarily from balsa wood and covered with a fuel-resistant covering. This ARF requires assembly and installation of your choice of servos and power system, and includes flaps, fiberglass cowl, painted pilot and other scale details. The large battery hatch affords ample room for either electric or gas setups. Impress at your flying field with this unique post-World War II utility aircraft!
    Fully Covered and Detailed
    The Nexa Dornier Do 27 comes fully covered including simulated panel lines and rivets.
    Scale Details Throughout
    There is no shortage of scale details with this Dornier Do 27 including functional flaps, detailed cockpit and painted pilot.
    Easy Battery Access
    The battery hatch is accessed simply and easily under the canopy.
    Fly A Unique Utility Craft
    The Dornier Do 27 is a unique German WWII utility aircraft that performs aerobatics with ease and style while supporting slow scale flying capability.
    • Complete Balsa and lite-ply construction for rigidity and durability
    • Covered from tip to tail in scale details including functional flaps, plastic seat, antenna, printed simulated panel lines and rivets
    • Fiberglass cowling for strength and durability
    • All control surfaces come out of the box pre-hinged and installed for convenience
    • Large battery hatch allows for your chosen electric or gas setup
    • Nexa Dornier Do 27 Army Version 1620mm (63") Wingspan - ARF
    • Wheels and spinner
    • Fuel tank, hardware and decals
    Requires:Gas Requires:Customer Note
    Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Intermediate
    BUILD TIME : 5+ Hours
    Model Scale 1/5.5
    Wingspan 1620mm / 63in
    Length 1210mm / 47.6in
    Empty Weight 2900g / 102.29oz
    CG (Center of Gravity) 65-68mm from the leading edge of the wing's root
    Power System 400Kv or equivalent brushless outrunner motor for electric or 2-stroke for gas (required)
    Electronic Speed Control 70A (required)
    Propeller / EDF 13x8 2-blade for electric or 12x6 2-blade for gas (required)
    Servos
    • 45g metal gear standard: left aileron, right aileron, elevator, rudder, - HRC6005-017
    • 17g metal gear standard: left flap, right flap - HRC6005-022
    Landing Gear Aluminum gear (included)
    Required Battery TWO 4 Cell 14.8V 4500 - 5000mAh LiPo Batteries (required for 8S setup)
    Required Radio 6+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights No
    Hinge Type CA fabric
    Material Balsa and light plywood
    Skill Level Intermediate
    Build Time 5+ Hours
