Official Nexa NE-1 Cub 2400mm ARF Discussion Thread
  • jbaartz
    • Sep 2020
    • 481
    The Piper J-3 Cub is an American light aircraft that was built between 1938 and 1947 by Piper Aircraft. The aircraft has a simple, lightweight design which gives it good low-speed handling properties and short-field performance. 230 dual-controlled versions were built for the United States Navy with a NE-1 designation.
    The Nexa NE-1 Cub can be built as either gas or electric powered, with a large door for battery access. Being lightweight with a high wing, this plane has a similar flying feel to a high wing trainer. Fully covered in weathered detail and including a working pilot door, this NE-1 Cub is perfect for those who love scale planes.
    • Complete Balsa and lite-ply construction for rigidity and durability
    • Covered from tip to tail in scale details
    • Large battery hatch allows for your chosen electric or gas setup
    • Nexa NE-1 Cub 2400mm (94.5") Wingspan - ARF
    • Landing gear and wheels
    • Hardware and decals
    Requires:Gas Requires:Customer Note
    Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine).
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Intermediate
    BUILD TIME : 6+ Hours
    Model Scale 1/4.5
    Wingspan 2400mm / 94.5in
    Length 1510mm /59.4in
    Empty Weight 5900g / 208.12oz
    CG (Center of Gravity) 90mm from the leading edge of the wing's root
    Power System 245Kv or equivalent brushless outrunner motor for electric or 2-stroke for gas (required)
    Electronic Speed Control 120A (required)
    Propeller / EDF 17x10 2-blade for electric or 16x7 2-blade for gas (required)
    Servos 45g standard servos: left aileron, right aileron, left elevator, right elevator, rudder - HRC6005-019
    Landing Gear Fixed (included)
    Required Battery 2x 5 Cell 18.5V 6000mAh LiPo batteries (8S setup required)
    Required Radio 5+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Hinge Type Nylon
    Material Balsa and light plywood
    Skill Level Intermediate
    Build Time 6+ Hours
  • zpilot
    • Mar 2020
    • 7
    • Denver, CO
    Is there a video on how to replace the covering on this model, after several years the covering is showing its age. I have the replacement covering just need some instruction
