Official Nexa Pilatus PC-6 Swiss 1580mm ARF Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    The full-size Pilatus PC-6 is a STOL workhorse capable of operating in rugged, short-field conditions for light transport roles.
    The Nexa Pilatus PC-6 Swiss is an accurate replica with all balsa construction. With a detailed covering and painted fiberglass cowl, the Pilatus PC-6 Swiss will make a beautiful addition to anyone's hangar and the pre-hinged control surfaces will have it in the air in no time.
    • Complete Balsa and lite-ply construction for rigidity and durability
    • Covered from tip to tail in scale details
    • Large battery hatch allows for your chosen electric or gas setup
    • Nexa Pilatus PC-6 Swiss 1580mm (62.2") Wingspan - ARF
    • Landing gear and wheels
    Requires:Gas Requires:Customer Note
    Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine).
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Intermediate
    BUILD TIME : 6+ Hours
    Model Scale 1/7.5
    Wingspan 1580mm / 62.2in
    Length 1160mm /45.7in
    Weight 2600g / 91.71oz
    CG (Center of Gravity) 74mm from the leading edge of the wing's root
    Power System 400Kv or equivalent brushless outrunner motor for electric or 2-stroke for gas (required)
    Electronic Speed Control 70A (required)
    Propeller / EDF 13x8 2-blade for electric or 12x6 2-blade for gas (required)
    Servos 45g standard servos: left aileron, right aileron, elevator, rudder - HRC6005-017
    Landing Gear Fixed (included)
    Required Battery 4 Cell 14.8V 4500 - 5000mAh LiPo batteries (required)
    Required Radio 5+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Hinge Type CA fabric
    Material Balsa and light plywood
    Skill Level Intermediate
    Build Time 6+ Hours
  • i_like_planes_27
    • Aug 2024
    • 17
    I just bought this plane, it’s not as big as I expected and the design and instructions are pretty bull. You will need to buy some glue and other screws that they don’t tell you. I haven’t even put the wings or motor in yet and the motor screws are the worst part. They are impossible to get on with the design they have made. Also requires a lot of drilling. I lowkey would NOT recommend this plane in general but especially for a first timer for ARF plane, actually all the NEXA planes that motion rc sells don’t buy for your first ARF get a different brand, these nexa planes are all German manufacturers so the directions are pretty off and confusing.
