Official Nexa King Quest Kodiak 2210mm ARF Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    This Nexa King Question Kodiak is brand new to the Nexa lineup at the end of 2022. This brand new aircraft is absolutely full of scale details. The full size King Quest Kodiak is a multi-purpose STOL plane and this model is a gorgeous replica of the original. With all the scale details and a 2200mm wingspan, this model is impressive from both near and far. Though this plane is large, the 2 piece wing can be fairly easily removed for transportation to and from the field. As with the original, this plane does not require a lot of runway for takeoff and landing. Handling is fantastic.
    This Nexa model can be setup with either gas or electric power system. The super large hatch allows easy access to either battery or fuel tank. Servo pockets make installed the standard size servos (control surfaces) and micro sized servos (flaps) a breeze.
    • Complete Balsa and lite-ply construction for rigidity and durability
    • Completely covered from tip to tail in scale details as shown
    • Large battery hatch allows for your chosen electric or gas setup
    • Functional pre-hinged landing flaps
    • Hand painted pilot
    • Stable landing gear with steerable nose gear
    • Nexa King Quest Kodiak 2210mm (87") Wingspan - ARF
    • Landing gear and wheels
    Requires:Gas Requires:Customer Note
    Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine).
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Intermediate
    BUILD TIME : 7+ Hours
    Model Scale 1/6
    Wingspan 2210mm / 87in
    Length 1580mm /62.2in
    Weight 5900g / 208.12oz
    CG (Center of Gravity) 95mm from the leading edge of the wing's root
    Power System 295Kv or equivalent brushless outrunner motor for electric or 2-stroke for gas (required)
    Electronic Speed Control 120A (required)
    Propeller / EDF 16x10 2-blade for electric or 14x8 2-blade for gas (required)
    Servos
    • 45g standard servos: left aileron, right aileron, left flap, right flap, nose gear wheel - HRC6005-019
    • 17g standard servos: left elevator, right elevator, rudder - HRC32082S
    Landing Gear Fixed (included)
    Required Battery 6 Cell 22.2V 5500mAh LiPo batteries (required)
    Required Radio 7+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights No
    Hinge Type Nylon
    Material Balsa and light plywood
    Skill Level Intermediate
    Build Time 7+ Hours
  • Captain MoMo
    Mach One
    • 69
    • Maryland, USA
    I have the Cessna C208 from Nexa and she doe snot have adequate wing loading IMO and stall way too quick. I hope this model with 6s is not too heavy and pose similar issues.
    • Captain MoMo
      Mach One
      • 69
      • Maryland, USA
      • Terminater007
        • 109
        hmmm private video :(
