Official Nexa Space Walker 1580mm ARF Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    Space Walker 1580mm (62.2") Wingspan - ARF from Nexa - NXA1050-001
    The Nexa Space Walker is a great model in the the world of scale airplanes. The Space Walker is an icon of American civil aviation. With a fantastic old-fashion design, including an open cockpit, inspired from aircraft that were produced in the 1930's, the Space Walker is especially cherished by amateur aircraft builders. The all-wood framework is covered in a red and yellow color-printed film that matches the traditional pattern of the full-size real-life aircraft. This ARF features all pre-covered balsa and light weight ply construction with pre-hinged control surfaces. Our recommend power system and electronics can be found below.
    • Complete Balsa and lite-ply construction for rigidity and durability
    • Covered from tip to tail in scale details
    • Large battery hatch allows for your chosen electric or gas setup
    • Nexa Space Walker 1580mm (62.2") Wingspan - ARF
    • Landing gear and wheels
    Requires:
    Gas Requires:
    Customer Note
    Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine).
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Intermediate
    BUILD TIME : 4+ Hours
    Model Scale 1/7.5
    Wingspan 1580mm / 62.2in
    Length 1020mm /40.2in
    Weight 2600g / 91.71oz
    CG (Center of Gravity) 89mm from the leading edge of the wing's root
    Power System 770Kv or equivalent brushless outrunner motor for electric or 2-stroke for gas (required)
    Electronic Speed Control 65A (required)
    Propeller / EDF 12x6 2-blade for electric or 12x6 2-blade for gas (required)
    Servos 45g standard servos: left aileron, right aileron, elevator, rudder - HRC6005-017
    Landing Gear Fixed (included)
    Required Battery 4 Cell 14.8V 4500 - 5000mAh LiPo batteries (required)
    Required Radio 5+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Hinge Type CA fabric
    Material Balsa and light plywood
    Skill Level Intermediate
    Build Time 4+ Hours
  • aferree61
    • Mar 2023
    • 5
    Well someone at Motion RC isn't doing there homework. I just bought one and bought 2 of the "Recommended" Admiral 5000mAh, 4, 14.8v batteries...THEY DON'T FIT!!!!!! Hey I have an Idea...Hire me to sample and QA your Planes because whomever is doing this, is either ignorant or just plain stupid
    • Dirt2Air
      • Jan 2026
      • 3
      Using all their recommended parts or pieces I ended up w/something that cannot even be flown!!!! Not enough battery space to move your 5000 mah batteries !!!!!
