Official Nexa C188 Agwagon 1920mm ARF Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    The Nexa C188 Agwagon is an electric or gas option agricultural plane with a 1920mm wingspan and is constructed primarily from balsa wood with scale details. This Nexa Agwagon can be run on either electric or gas. This Nexa plane includes many scale details such as a detailed cockpit, painted pilot, and detailed covering. The balsa and light weight ply constriction is full covered and the cowl is fiberglass. The sturdy landing gear on this plane is aluminum. All control surfaces are pre-hinged to make the build easy. Our recommendations for power system and electronics are below.
    • Complete Balsa and lite-ply construction for rigidity and durability
    • Covered from tip to tail in scale details
    • Large battery hatch allows for your chosen electric or gas setup
    • Nexa C188 Agwagon 1920mm (75.6") Wingspan - ARF
    • Landing gear and wheels
    Requires:Gas Requires:Customer Note
    Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine).
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Intermediate
    BUILD TIME : 6+ Hours
    Model Scale 1/6.5
    Wingspan 1920mm / 75.6in
    Length 1300mm /51.2in
    Weight 3900g / 137.57oz
    CG (Center of Gravity) 151mm from the leading edge of the wing's root
    Power System 295Kv or equivalent brushless outrunner motor for electric or 2-stroke for gas (required)
    Electronic Speed Control 120A (required)
    Propeller / EDF 16x10 2-blade for electric or 14x8 2-blade for gas (required)
    Servos 45g standard servos: left aileron, right aileron, elevator, rudder, left flap, right flap - 36645
    Landing Gear Fixed (included)
    Required Battery TWO 4 Cell 14.8V 5000-6000mAh LiPo batteries (required)
    Required Radio 7+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights No
    Hinge Type Nylon
    Material Balsa and light plywood
    Skill Level Intermediate
    Build Time 6+ Hours
  • sx700r
    • Jan 2022
    One post! Does anyone like this plane enough to even make a statement? It’s so hard to find anything about it other than what the manufacturer says
