Official Nexa Stick F-1500 1540mm ARF Discussion Thread
  • jbaartz
    • Sep 2020
    • 488
    The Stick F-1500 is a relaxing balsa plane which is perfect for two types of pilots. If you are looking to get into balsa, this is the perfect place to start. This flies like a high wing trainer and is an easy build. It is a perfect entry into the world of balsa planes. If you are a more advanced pilot looking for a relaxing flight, this is it. This is a versatile balsa sport trainer and sport flyer that can be built as either electric or gas powered. It has a removable hatch to easily access either a fuel tank or flight batteries, including a removable battery tray. Tough and practical, this popular sport plane is easy to transport and the perfect size for a club trainer.
    • Complete Balsa and lite-ply construction for rigidity and durability
    • Covered from tip to tail in scale details
    • Large battery hatch allows for your chosen electric or gas setup
    • Nexa Stick 1540mm (60.9") Wingspan - ARF
    • Landing gear and wheels
    Requires:Gas Requires:Customer Note
    Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine).
    Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Intermediate
    BUILD TIME : 3+ Hours
    Model Scale N/A
    Wingspan 1540mm / 60.9in
    Length 1130mm /44.5in
    Weight 2200g / 77.60oz
    CG (Center of Gravity) 89mm from the leading edge of the wing's root
    Power System 890Kv or equivalent brushless outrunner motor for electric or 2-stroke for gas (required)
    Electronic Speed Control 65A (required)
    Propeller / EDF 12x6 2-blade for electric or 12x6 2-blade for gas (required)
    Servos 45g standard servos: left aileron, right aileron, elevator, rudder - HRC6005-017
    Landing Gear Fixed (included)
    Required Battery 4 Cell 14.8V 4000 - 5000mAh LiPo batteries (required)
    Required Radio 5+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Hinge Type CA fabric
    Material Balsa and light plywood
    Skill Level Intermediate
    Build Time 3+ Hours
