Official Nexa 1580mm G35 Sport V-Tail Thread
    G35 Sport V-Tail 1580mm (62") Wingspan - ARF from Nexa - NXA1030-001
    The G35 Sport is an American general aviation aircraft introduced in 1947 by Beech Aircraft Corporation of Wichita, Kansas. The six-seater, single-engined aircraft is still being produced by Beechcraft and has been in continuous production longer than any other aircraft in history.
    The Nexa G35 Sport V-Tail is a electric or gas option .46-size aerobatic airplane with a 1580mm wingspan, constructed primarily from balsa wood and covered with a fuel-resistant covering. This ARF requires assembly and installation of your choice of servos and power system, and includes fully functional flaps, fiberglass cowl, painted pilot, detailed cockpit and other scale details. The large battery hatch affords ample room for either electric or gas setups. Impress at your flying field with this iconic civil aircraft!
    Fully Covered and Detailed
    The Nexa Bonanza V-Tail comes fully covered including weathering, simulated panel lines and rivets.
    Scale Details Throughout
    There is no shortage of scale details with this Bonanza V-Tail including functional flaps, detailed cockpit and painted pilot.
    Fiberglass Cowling
    The cowl is made of fiberglass for both looks and durability.
    Fly A Classic Civil
    The Bonanza V-Tail is an iconic and ubiquitous civillian aircraft capable of both aerobatic flights and scale cruising.
    • Complete Balsa and lite-ply construction for rigidity and durability
    • Covered from tip to tail in scale details including functional flaps, plastic seat, antenna, printed simulated panel lines and rivets
    • Fiberglass cowling for strength and durability
    • All control surfaces come out of the box pre-hinged and installed for convenience
    • Large battery hatch allows for your chosen electric or gas setup
    • Nexa G35 Sport V-Tail 1580mm (62") Wingspan - ARF
    • Wheels and spinner
    • Fuel tank, hardware and decals
    Requires:Gas Requires:Customer Note
    Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine).
    Product Specifications:
    AGE LEVEL :14 and up
    SKILL LEVEL :intermediate
    BUILD TIME :6+ hours
    Model Scale 1/7.5
    Wingspan 1580mm / 62.2in
    Length 1170mm / 46.0in
    Empty Weight 3200g / 112.87oz
    CG (Center of Gravity) 128mm from the leading edge of the wing's root
    Power System 580Kv or equivalent brushless outrunner motor for electric or .46 - .70 (7.45cc - 11.5cc) for gas (required)
    Electronic Speed Control 70-85A (required)
    Propeller / EDF 13x8 2-blade for electric or 12x6 2-blade for gas (required)
    Servos 45g metal gear standard: left aileron, right aileron, elevator, rudder - HRC6005-017
    17g metal gear standard: left flap , right flap - HRC6005-022
    Landing Gear Electronic retractable gear (required)
    Required Battery 4 Cell 14.8V 4500 - 5000mAh LiPo Battery (required)
    Required Radio 7+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights No
    Hinge Type CA fabric
    Material Balsa and light plywood
    Skill Level Intermediate
    Build Time 6+ Hours
  • Blackst4rr
    Trabuco Flyers Training Director
    • Aug 2019
    • South CA
    Any news on retract availability, or does anyone know where to get .40 size or 4kg rated trike retracts? Nothing in stock in most places currently. Surprised the ARF doesn't come with a set of fixed wires for gear.
    • steveh94
      • Oct 2020
      • 4
      • Placerville, CA
      Does this Plane come with fixed landing gear?
      • steveh94
        • Oct 2020
        • 4
        • Placerville, CA
        I bought the plane, it does come with fixed gear. Anyone know what a good alternative retract and strut set is? The Nexa ones are out of stock
        • Terminater007
          • 109
          just use the Servoless Retract with Metal Trunion 44mm x 41mm Mount (2pcs)
          and Servoless Steerable Nose Retract with Metal Trunion 44mm x 41mm Mount
          which should fit from hobbyking
          and a set of struts.. which u will have to measure
