Official Nexa 1540mm Messerschmitt BF-109 ARF Thread
    • 8205
    Messerschmitt BF-109 1540mm (60") Wingspan - ARF from Nexa - NXA1025-001
    The Messerschmitt Bf-109 is a German World War II fighter aircraft that was, along with the Focke-Wulf Fw 190, the backbone of the Luftwaffe's fighter force.
    The Nexa Messerschmitt BF-109 is a electric or gas option .46-size aerobatic airplane with a 1540mm wingspan, constructed primarily from balsa wood and covered with a fuel-resistant covering. This ARF requires assembly and installation of your choice of servos and power system, fully functional flaps, fiberglass cowl, painted pilot and other scale details. The large battery hatch affords ample room for either electric or gas setups. Impress at your flying field with this iconic World War II axis warbird!
    Fully Covered and Detailed
    The Nexa Messerschmitt BF-109 comes fully covered including simulated panel lines and rivets.
    Scale Details Throughout
    There is no shortage of scale details with this Messerschmitt BF-109 including functional flaps, detailed cockpit and painted pilot.
    Fiberglass Cowling
    The cowl is made of fiberglass for both looks and durability.
    Fly An Axis Classic
    The Messerschmitt BF-109 is an iconic German WWII warbird that performs aerobatics with ease and style and looks menacing while doing it.
    • Complete Balsa and lite-ply construction for rigidity and durability
    • Covered from tip to tail in scale details including functional flaps, plastic seat, antenna, printed simulated panel lines and rivets
    • Fiberglass cowling for strength and durability
    • All control surfaces come out of the box pre-hinged and installed for convenience
    • Large battery hatch allows for your chosen electric or gas setup
    • Nexa Messerschmitt BF-109 1540mm (60") Wingspan - ARF
    • Wheels and spinner
    • Fuel tank, hardware and decals
    Requires:Gas Requires:Customer Note
    Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine).
    Product Specifications:
    AGE LEVEL :14 and up
    SKILL LEVEL :intermediate
    BUILD TIME :6+ hours
    Model Scale 1/7.5
    Wingspan 1540mm / 60.6in
    Length 1120mm / 44.0in
    Empty Weight 3100g / 109.34oz
    CG (Center of Gravity) 88-92mm from the leading edge of the wing's root
    Power System 580Kv or equivalent brushless outrunner motor for electric or .46 - .70 (7.45cc - 11.5cc) for gas (required)
    Electronic Speed Control 70-85A (required)
    Propeller / EDF 13x8 2-blade for electric or 12x6 2-blade for gas (required)
    Servos 45g metal gear standard: left aileron, right aileron, elevator, rudder - HRC6005-017
    17g metal gear standard: left flap , right flap - HRC6005-022
    Landing Gear Electronic retractable gear (required)
    Required Battery 4 Cell 14.8V 4500 - 5000mAh LiPo Battery (required)
    Required Radio 6+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights No
    Hinge Type CA fabric
    Material Balsa and light plywood
    Skill Level Intermediate
    Build Time 6+ Hours
  • ncflyer79
    Jarrod “P-47 Thunderbolt and Luftwaffe fanatic”
    • 42
    • Marion, NC
    This is considered sport scale right????
      • 8205
      Yes it would be.
      • Randy H
        • 63
        • Surprise AZ
        This has got to be a sport scale, It kind of looks like an e model 109. The landing gear is in the wrong place and the outline of the model is way off. To bad it is not truer to scale it looks more sport scale than anything else.
          • 8205
          It's definitely sports scale. I had the Nexa P-38. While it was sports scale, it flew fabulously and still had the general look I was after.
          • Randy H
            • 63
            • Surprise AZ
            True this may be a good choice for someone who wants a model that kind of has the ME 109 looks. I was hoping for a motion would come out with a more scale like 109. We can always hope.
              • 8205
              FlightLine please pickup the white courtesy phone!
              • Randy H
                • 63
                • Surprise AZ
Name:	ME 109 g6.jpg
ID:	365301This is an ME109G6 I built from a Sky Shark kit years ago. I was hoping that Motion would come out with something like this with more detail. This 109 is in Italian air force colors.
                • edwen303
                  • 4
                  Is there a thread in rcgroups on this model, or VQ 60 size 109? How is the chance the main wheel well being modified to a scale location?
                  Attached is the picture from VQ site
                  Click image for larger version  Name:	Messerschmitt-Bf-109_VQA031_10.jpg Views:	0 Size:	32.1 KB ID:	366608
                  • Creative RC
                    • Sep 2018
                    • 16
                    I prefer that the gear is spread further apart than scale. This certainly helps with the landings (the most challenging part of flying) and is the reason it is designed this way.
                      • 8205
                      I am all about scale detail but Creative RC is correct. It was purposefully made not true to scale for the very reason of making it not as challenging and frustrating to takeoff and land. The scale positioning of the BF-109's closely set and minimally-raked gear can be a real nightmare for RC pilots to deal with.
