Official Nexa 1510mm Focke Wulf FW-190A ARF Thread
    • 8228
    Focke Wulf FW-190A 1510mm (59") Wingspan - ARF from Nexa - NXA1029-001
    Click image for larger version  Name:	master.jpg Views:	0 Size:	103.9 KB ID:	365445
    The Focke-Wulf Fw 190 Würger was a German single-seat, single-engine fighter aircraft designed by Kurt Tank at Focke-Wulf in the late 1930s and widely used during World War II. Along with its well-known counterpart, the Messerschmitt Bf 109, the Fw 190 became the backbone of the Jagdwaffe of the Luftwaffe.
    The Focke Wulf FW-190A is a electric or gas option .46-size aerobatic airplane with a 1510mm wingspan, constructed primarily from balsa wood and covered with a fuel-resistant covering. This ARF requires assembly and installation of your choice of servos and power system, and includes fully functional flaps, fiberglass cowl, painted pilot and other scale details. The large battery hatch affords ample room for either electric or gas setups. Impress at your flying field with this iconic World War II axis warbird!
    Visit the Official Nexa Focke Wulf FW-190A 1510mm ARF Discussion Thread on HobbySquawk.com for additional photos, videos, reviews, and customer Q&A.
    Fully Covered and Detailed
    The Nexa Focke Wulf FW-190A comes fully covered including simulated panel lines and rivets.
    Scale Details Throughout
    There is no shortage of scale details with this Focke Wulf FW-190A including functional flaps, detailed cockpit and painted pilot.
    Easy Battery Access
    The battery hatch is ingeniously accessed through the side of the fuselage for easy access.
    Fly An Axis Classic
    The Focke Wulf FW-190A is an iconic German WWII warbird that performs aerobatics with ease and style and looks menacing while doing it.
    • Complete Balsa and lite-ply construction for rigidity and durability
    • Covered from tip to tail in scale details including functional flaps, plastic seat, antenna, printed simulated panel lines and rivets
    • Fiberglass cowling for strength and durability
    • All control surfaces come out of the box pre-hinged and installed for convenience
    • Large battery hatch allows for your chosen electric or gas setup
    • Nexa Focke Wulf FW-190A 1510mm (59") Wingspan - ARF
    • Wheels and spinner
    • Fuel tank, hardware and decals
    Requires:Gas Requires:Customer Note
    Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine).
    Product Specifications:
    AGE LEVEL :14 and up
    SKILL LEVEL :intermediate
    BUILD TIME :6+ hours
    Model Scale 1/7.5
    Wingspan 1500mm / 59.0in
    Length 1092mm / 43.0in
    Empty Weight 3100g / 109.34oz
    CG (Center of Gravity) 107mm from the leading edge of the wing's root
    Power System 580Kv or equivalent brushless outrunner motor for electric or .46 - .70 (7.45cc - 11.5cc) for gas (required)
    Electronic Speed Control 70-85A (required)
    Propeller / EDF 13x8 2-blade for electric or 12x6 2-blade for gas (required)
    Servos 45g metal gear standard: left aileron, right aileron, elevator, rudder - HRC6005-017
    17g metal gear standard: left flap , right flap - HRC6005-022
    Landing Gear Electronic retractable gear (required)
    Required Battery 4 Cell 14.8V 4500 - 5000mAh LiPo Battery (required)
    Required Radio 6+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights No
    Hinge Type CA fabric
    Material Balsa and light plywood
    Skill Level Intermediate
    Build Time 6+ Hours
