Hi the slats on my bison are warped any ideas on how to straighten them . Also does it make any difference if they are warped.
Bison xt slats
Tags: None
Are they installed on the plane or are they not on yet? Attach a picture so we can see how bad it is. Are they foam or plastic? You can try applying a hot towel (hot water - wring it out) and cover the slat with it for a minute or two. Then quickly put it in a sort of "press" (light pressure) till it cools. However, not seeing it and not knowing how warped it is, makes it hard to comment precisely.
