Version Info: This model is an RTF ("Ready To Fly") which includes everything you need to fly out of the box (battery, charger and transmitter). Only 4 AAA batteries are required for the transmitter. This is also available in an FTR (Futaba Transmitter Ready) format here, which just requires an S-FHSS radio.
With special introductory pricing, Motion RC is introducing a new line of small planes. This is an easy flying 360mm Micro RTF sport scale biplane for beginners and advanced pilots alike. Its ultra light flying weight lets you fly it everywhere without worrying about air regulations. With the help of the built-in, versatile and smart flight control board, this plane makes it possible for almost anyone to learn to fly successfully, without worrying about losing control and crashing. This Skynetic micro bi-plane can be flown in beginner 6 axis mode, 3 axis mode, or can be completely turned off with the touch of a button on the transmitter.
Not only was this plane designed to fly well but it was also designed with super easy maintenance in mind. The detachable wings grant access to the servos and control board, if they ever need to be repaired or replaced. The motor and motor mount, prop and prop saver, and landing gear are also easily removed using a glue-free assembly.
If you want to use your own S-FHSS radio, you can bind them easily with the help of the mini Sbus receiver, sold separately.
Ready To Fly Perfect for new pilots starting with their first RC airplane, the Skynetic Pitts Special includes everything in the box to begin flying in minutes except for four AA batteries. Motion RC also stocks a complete line of spare parts to keep you flying. |
Easily Transported The main wings are removable and have a glue-free assembly for extra portability so you can fly when and where you want. |
Detachable Landing Gear The fixed main landing gear effortlessly detaches for belly landings and easier hand launching. |
Easily Repaired The motor mount, prop with prop saver, and flight control board are easy to repair or replace, if needed. |
Durable Materials High quality, durable EPP material and built-in carbon fiber wind spars make the Pitts Special sturdy and crash resistant. |
Display Stand The included dedicated stand allows for the plane to be displayed in a static position, ensuring your model looks great on the shelf. |
- The first and easiest to fly Micro RTF high scale biplane for beginners
- Replaceable motor mount, prop saver, and flight control board
- Detachable main wing and landing gear with glue-free assembly
- One Key LOITER Function: the plane will keep circling in a 20m diameter circle in any altitude
- Equipped with a 6-axis gyro
- Three different flying modes (6G / 3D / Manual) can be changed with the press of a button
- Different sensitivity options: one button to choose different sensitivity for control surfaces (beginner or expert)
- Includes an auto-launch feature for easy hand launches
- Reliable radio control for distances up to 150 meters without loss of signal
- Low battery indicator for the transmitter battery
- Throttle protection: the throttle will not engage unless it's unlocked while you power on the plane
- Digital trimming
- The quick-charge USB charger will fully charge the battery in 40 minutes
- High quality durable EPP material and built-in carbon fiber spars
- Pre-applied vivid decals make your plane easy see in the sky
- Dedicated stand to hold the plane for static display
- Skynetic Pitts Special with Gyro 360mm (14.2") Wingspan - RTF
- 2.4 GHz 6CH radio controller
- 2.4 GHz receiver
- 1S 3.7V 500mAh LiPo battery
- USB charger
- Landing gear set
- Owner's manual
- Screwdriver
- Four (4) AAA size batteries for the radio transmitter – we recommend Admiral 750mAh 1.2V NiMH AAA Rechargeable Batteries (4 Pack)
HELPFUL TIP: If you are new to radio control (RC) we recommend that you read through our RC resource known as our "Knowledge Blog". It's jam packed with helpful information for beginners including how to articles, support videos, a glossary of terms and much more. Click Here to go to our Knowledge Blog's Beginner Section. For further assistance, please do not hesitate to contact our Customer Support Team and one of our knowledgeable RC experts will be glad to assist you. Happy flying!
Product Specifications:
AGE LEVEL : 14 and up
SKILL LEVEL : Beginner
BUILD TIME : None
| Model Scale | N/A |
| Wingspan | 360mm / 14.2in |
| Length | 300mm / 11.8in |
| Weight | 75g / 2.65oz |
| CG (Center of Gravity) | N/A |
| Power System | 1023 coreless motor (installed) |
| Electronic Speed Control | Integrated |
| Propeller / EDF | 2-blade electric propeller |
| Servos |
| Landing Gear | Triangle, detachable |
| Required Battery | 1S 3.7V 500mAh LiPo (included) |
| Required Radio | 2.4GHz 6CH transmitter (included) |
| Ailerons | Yes |
| Elevator | Yes |
| Rudder | Yes |
| Flaps | No |
| Lights | No |
| Hinge Type | Foam |
| Material | EPP Foam |
| Skill Level | Beginner |
| Build Time | None |
