Official 360mm Tiger Moth EPP with Gyro RTF Thread
    • 8205
    Tiger Moth EPP with Gyro 360mm (14.1") Wingspan - RTF - from Skynetic - SKY1056-001
    Version Info: This model is an RTF ("Ready To Fly") which includes everything you need to fly out of the box (battery, charger and transmitter). Only 4 AAA batteries are required for the transmitter.
    With special introductory pricing, Motion RC is introducing a new line of small planes. This 360mm Micro RTF classic biplane from Skynetic is a terrific airplane for beginners and advanced pilots alike. The ultra-light flying weight allows you to fly it in virtually any environment with some open space from backyards to parks and more. With the help of the built-in, versatile and smart flight control board, this plane makes it possible for almost anyone to learn to fly successfully, without worrying about losing control and crashing. This Skynetic Tiger Moth can be flown in beginner 6 axis mode, 3 axis mode, or the gyro can be completely turned off with the touch of a button on the transmitter.
    Designed for ease of maintenance, the detachable wings grant access to the servos and control board, if they ever need to be repaired or replaced. The motor and motor mount, prop and prop saver, and landing gear are also easily removed using a glue-free assembly.
    Auto-Circle Mode
    With the simple press of a button you can place your SkyneticTiger Moth into an automatic circular pattern of approximately 20 meters at any altitude.
    6-Axis High Sensitivity Gyro
    Three different flying modes (6G / 3D / Manual) are available with the press of a button thanks to the onboard gyro.
    Ease of Maintenance
    The detachable wings grant access to the servos and control board, if they ever need to be repaired or replaced. The motor and motor mount, prop and prop saver, and landing gear are also easily removed using a glue-free assembly.
    Attractive Display Stand
    When you are not flying the Skynetic Tiger Moth, display the model eloquently with the included display stand.
    • Comes with gyro for increased stability and helps decrease the chance of a crash
    • Compact size and nice scale look appeals to both novice and advanced pilots
    • Powerful coreless motor supports a wide flight envelope from slow to aerobatic flight
    • Removable wings and landing gear for ease of transportation to and from the flying field
    • Crash-resistant EPP foam
    • Skynetic Tiger Moth EPP with Gyro 360mm (14.1") Wingspan - RTF
    • 2.4 GHz 6CH Radio Controller
    • 2.4 GHz Receiver
    • 1S 3.7V 500mAh LiPo Battery
    • USB Charger
    • Landing gear set
    • Owner's Manual
    • Screwdriver
    Requires:New to RC?  We can help!
    HELPFUL TIP: If you are new to radio control (RC) we recommend that you read through our RC resource known as our "Knowledge Blog". It's jam packed with helpful information for beginners including how to articles, support videos, a glossary of terms and much more. Click Here to go to our Knowledge Blog's Beginner Section. For further assistance, please do not hesitate to contact our Customer Support Team and one of our knowledgeable RC experts will be glad to assist you. Happy flying! Product Specifications:
    AGE LEVEL :14 and up
    SKILL LEVEL :Beginner
    BUILD TIME :none
    Model Scale N/A
    Wingspan 360mm / 14.1in
    Length 300mm / 11.8in
    Weight 75g / 2.64oz
    CG (Center of Gravity) Refer to the owner's manual
    Power System 1023 Coreless Motor (installed)
    Electronic Speed Control Integrated
    Propeller / EDF 2-blade electric propeller
    Servos
    • 2x 1.3g micro: elevator, rudder, 2x 2g micro: ailerons
    Landing Gear Fixed/Detachable
    Required Battery 1S 3.7V 500mAh LiPo (included)
    Required Radio 6CH 2.4GHz Transmitter (included)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Hinge Type Foam
    Material EPP Foam
    Skill Level Beginner
    Build Time None
    • 4819
    Aros, hah,
    I bought one these because Tamms wants to try it out.
    Her reasoning is "it's yellow" and "pretty".
    I am a bit nervous about being her IP, but we've gotten through worse.
    It is a bit small for a trainer, but with the gyro setting these are hard crash.
    With the Mustang, I've found gyro on, just let go of the sticks, and add a little up elevator gets you out of most issues.
    Wind will be a factor with the biplane configuration.
    Looking forward to it.
    Best, LB
    • Streffman
      • Jan 2024
      Can this be used with a 4in1 module in a Radiomaster or can a Spektrum remote receiver be used as in the small warbirds?
      • testfly
        • May 2024
        • 12
        I bought one and flying it with a Lemon RC DSMP receiver. I need info on how to set up the switches. I seen a video giving this info but I can't remember where. The model flys well. But, when I turn off the gyro it goes vertical to the point of stalling so I need to get the radio setup proper to get the most from the model. Any help would be great. Thanks In Advance.
        • Potshot
          • Feb 2024
          Did you ever get an answer? I need this info, too. Thanks!
          • Randy Hills
            • Mar 2025
            Has anyone changed out the servo's in this model or any of the small EPP Skynetic's? I find that the servo's have a hard time returning to the neutral position, and it takes jogging (the rudder and elevator especially ) servo's to get them back in line..Itr's almost like the servo's don't have the torque to pull the control surfaces all the way back without hitting the stick a few times. I was planning to put in a couple of tiny servo's with a bit more torque to see if that helps. I checked the clearance of the servo arms and they don't seem to be binding on the inside of the fuse, and the control linkages look tight but the little buggers hang up when I center the sticks after using the elevator or rudder. Ailerons work perfect. I noticed the issue on the preflight and figured I'd try it anyway and was able to do a few laps of the field, but had to consistently tap the sticks to straighten her out after a turn and both control surfaces didn't want to center after,,,, I have a Stearman and a ME and they work perfect....It's just happening on this D.H. Tiger Moth.
            Just curious if this is common with these little guys, and what servo's anyone has found that remedies this....
            Thanks,
            Randy
