Official Skynetic 400mm P-40 EPP with Gyro Thread
    P-40 EPP with Gyro 400mm (15.7") Wingspan from Skynetic
    Version Info: This model is an RTF ("Ready To Fly") which includes everything you need to fly out of the box (battery, charger and transmitter). Only 4 AAA batteries are required for the transmitter.
    With special introductory pricing, Motion RC is introducing a new line of small planes. This 400mm Micro RTF iconic P-40 Warhawk from Skynetic is a terrific airplane for beginners and advanced pilots alike. The ultra-light flying weight allows you to fly it in virtually any environment with some open space from backyards to parks and more. With the help of the built-in, versatile and smart flight control board, this plane makes it possible for almost anyone to learn to fly successfully, without worrying about losing control and crashing. This Skynetic P-40 can be flown in beginner 6 axis mode, 3 axis mode, or the gyro can be completely turned off with the touch of a button on the transmitter.
    Designed for ease of maintenance, the detachable wing grants access to the servos and control board, if they ever need to be repaired or replaced. The motor and motor mount, prop and prop saver, and landing gear are also easily removed using a glue-free assembly.
    Ready To Fly Out Of The Box
    The Skynetic P-40 is completely ready to fly right out of the box. Simply charge the battery and go fly!
    Ease of Maintenance
    The detachable wing grants access to the servos and control board, if they ever need to be repaired or replaced. The motor and motor mount, prop and prop saver, and landing gear are also easily removed using a glue-free assembly.
    Removable Landing Gear
    You can easily remove and add the landing gear based on your preference. Simply clip them in place or detach from the slot.
    Parts Are Easy To Replace
    The P-40 is incredibly easy to replace any parts. The model is designed for easy access to any key component.
    • Comes with gyro for increased stability and helps decrease the chance of a crash
    • Compact size and nice scale look appeals to both novice and advanced pilots
    • Powerful coreless motor supports a wide flight envelope from slow to aerobatic flight
    • Removable wings and landing gear for ease of transportation to and from the flying field
    • Crash-resistant EPP foam
    • Skynetic P-40 EPP with Gyro 400mm (15.7") Wingspan - RTF
    • 2.4 GHz 6CH Radio Controller
    • 2.4 GHz Receiver
    • 1S 3.7V 500mAh LiPo Battery
    • USB Charger
    • Landing gear set
    • Owner's Manual
    • Screwdriver
    Requires:New to RC?  We can help!
    HELPFUL TIP: If you are new to radio control (RC) we recommend that you read through our RC resource known as our "Knowledge Blog". It's jam packed with helpful information for beginners including how to articles, support videos, a glossary of terms and much more. Click Here to go to our Knowledge Blog's Beginner Section. For further assistance, please do not hesitate to contact our Customer Support Team and one of our knowledgeable RC experts will be glad to assist you. Happy flying! Product Specifications:
    AGE LEVEL :14 and up
    SKILL LEVEL :Beginner
    BUILD TIME :none
    Model Scale N/A
    Wingspan 400mm / 15.7in
    Length 330mm / 12.9in
    Weight 75g / 2.64oz
    CG (Center of Gravity) Refer to the owner's manual
    Power System 1023 Coreless Motor (installed)
    Electronic Speed Control Integrated
    Propeller / EDF 3-blade electric propeller
    Servos
    • 2x 1.3g micro: elevator, rudder, 2x 2g micro: ailerons
    Landing Gear Fixed/Detachable
    Required Battery 1S 3.7V 500mAh LiPo (included)
    Required Radio 6CH 2.4GHz Transmitter (included)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Hinge Type Foam
    Material EPP Foam
    Skill Level Beginner
    Build Time None
  • w9jwn
    • Dec 2023
    Is this Bindable.
      • 5426
      It comes with t's own transmitter. It is not compatible with Spektrum if that's what you are asking.
      • BeavisMcGee
        • Feb 2024
        I just picked up the Futaba Transmitter Ready version (FTR), and got it to bind to my T14SG, but have a few questions im hoping someone can help with
        • How do you map the TX for gyro settings? I saw the video on youtube saying its mapped to channel 5, but I havent been able to get it to change settings regardless of what settings on channel 5 I adjust (switch, EPA, reversing, sub trim, etc.). What am i missing?
        • Is there a way to get it into "Loiter" mode? And if so, how/what channel/what settings need to be configured?
        • Is there any info about recommended control throws? Nothing in the manual or online that i could find.
        Thanks in advance for any help!
          • 4877
          BeavisMcGee, BMc, Welcome to "The Squawk"! Glad to have you onboard, Sir.
          I have the Skynetics Mustang and the Gypsy Moth.
          We bought those with the OEM Tx. I have wanted to add the Warhawk and I fly Futaba, so your question is highly relevant for my as well.
          I have used the "Loiter" mode and it is a decent option, unfortunately I have no clue how that would set up For a Futaba Tx.
          You might send a private message to James the marketing representative for MotionRC or to Wesley, the product specialist for MotonRC.
          Wesley has made a great flying and setup video on the Mustang when it was first introduced though he had the OEM TX.
          My guess is he would be the person most likely and able to assist you.
          Best, LB
          • sweendog1969
            • Mar 2023
            • 4
            Anybody have problems flying these? I bought the futaba version and am using a radiomaster 16s. My plane feels wobbly (tail heavy) and under powered. If i turn off the gyro its impossible to fly and with a gyro on it wants to stall and roll over
              • 4877
              sweendog1969 Yes I have the Mustang and the Tiger Moth. The Mustang is very difficult to fly without the gyro on and it feels tail heavy. I will tweek on it some over the Summer, But it is quick and easy to transport. The Bi-Plane is much easier to fly, though I have not flown it without the gyro on. Best, LB
