Official Nexa 1620mm DHC-2 Beaver ARF Thread
    DHC-2 Beaver 1620mm (63.7") Wingspan - ARF from Nexa
    The Nexa DHC-2 Beaver is based on the single-engined, high-wing, propeller-driven STOL aircraft designed and built by de Havilland Canada. Commonly used as a bush plane, it has been deployed in a broad array of applications, ranging from cargo/passenger transport to crop dusting and aerial topdressing to civilian aviation.
    The Nexa DHC-2 Beaver is a .46 size electric STOL aircraft with a 1620mm wingspan, constructed primarily from balsa wood and covered in the Kenmore Air livery. This ARF requires assembly and installation of your choice of servos and power system, and includes two piece wing with aluminum wing joiner, fiberglass cowl and operational pilot door. A large battery tray provides ample space for any size battery you require.
    • Whistler Air livery for scale appeal and added detail
    • Complete Balsa and lite-ply construction for rigidity and durability
    • Two piece wing with aluminum wing joiner for easy transport
    • Large battery tray provides ample space for any size battery you require
    • Functional pilot door and well appointed throughout
    • Fiberglass cowling for strength and durability
    • All control surfaces come out of the box pre-hinged and installed for convenience
    • Nexa DHC-2 Beaver 1620mm (63.7") Wingspan - ARF
    • Plywood seat
    • Fibreglass cowling
    • Electric motor mount
    • Aluminium landing gear & wheels
    • Aluminium wing joiner
    • Wing struts
    • Engine mounts
    • Spinner
    • Fuel tank
    • Decals and all hardware
    Requires:Gas Requires:Customer Note
    Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
    AGE LEVEL :14 and up
    SKILL LEVEL :intermediate
    BUILD TIME :6+ hours
    Model Scale 1/6.6
    Wingspan 1620mm / 63.7in
    Length 1115mm / 43.9in
    Weight 3400g / 120oz
    CG (Center of Gravity) 70-75mm from the leading edge of the wing root
    Power System 650W brushless outrunner motor (required)
    Electronic Speed Control 85A (required)
    Propeller / EDF 13x8 2-blade for electric, 11x6 gas (required)
    Servos
    • 3x 45g standard servos for ailerons - HRC32645S
    • 2x 17g standard servos for elevator and rudder - HRC32225S
    Landing Gear Fixed (included)
    Required Battery 5 Cell 18.5V 4000 LiPo battery (required)
    Required Radio 5+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Hinge Type Nylon
    Material Balsa and light plywood
    Skill Level Intermediate
    Build Time 6+ Hours
