Official Black Horse 1780mm Focke-Wulf 190A ARF Thread
    • 8207
    Focke-Wulf 190A 1780mm (70.1") Wingspan from Black Horse - Balsa Wood ARF - BHM1012-001
    The Focke-Wulf FW 190 is a legendary German single-seat, single-engine fighter aircraft that was developed in the late 1930s and played a crucial role during World War II. Alongside the well-known Messerschmitt BF 109, the FW 190 was the cornerstone of the Luftwaffe's Jagdwaffe (Fighter Force). Its powerful twin-row BMW 801 radial engine gave it the ability to carry heavier loads compared to the BF 109, allowing it to serve as a versatile day fighter, fighter-bomber, ground-attack aircraft, and even as a night fighter to some extent.
    Experience the power and precision of this legendary aircraft in model scale from Black Horse! Scaled to approximately 1:6 with attention paid to a true to original appearance with favorable flight characteristics. The model can be operated using an electric power system or with an internal combustion engine about 26cc displacement.
    Scale Simulated Covering
    The printing and covering on the FW 190A has scale rivet and panel line detail and weathering that elevates the model to a whole new level of scale appeal.
    Electric Retractable Landing Gear
    Adding to the scale appeal, the FW 190A comes with electric retracts with CNC machined oleo struts.
    Gas or Electric Power
    You can choose between gas or electric to power your model depending on your preference. Check the specifications for recommendations.
    Bold Presence
    This FW 190A has a nice mid-range 70" wingspan for solid presence both in the air and on the ground.
    Removable Main Wing
    Easy assembly and intuitive design allows for the main wing to be removed for transport.
    Detailed Cockpit and Pilot
    The painted pilot and detailed cockpit provides that extra layer of scale detail that is sure to impress during states of static display.
    • Electric retractable gear with oleo CNC suspension metal struts
    • Lightweight, strong, laser cut balsa and plywood construction
    • Panel lines and details printed directly onto the pre-applied, high quality covering
    • Aerofoiled tail surfaces
    • Recessed hinges on all control surfaces
    • Pre-drilled hinge mounting holes
    • Heavy-duty pin hinges on all control surfaces
    • Split flaps for easier landings and shorter takeoffs
    • Painted and detailed cockpit, pilot and interior included
    • Fiberglass control horns with ball link connector
    • Two-piece, plug-in wings simplify transportation and assembly
    • Fiberglass cowl and glass reinforced landing gear covers/pants
    • Black Horse Focke-Wulf 190A 1780mm (70.1") Wingspan - ARF
    • Instruction manual
    Requires (Electric):Requires (Gas):Customer Note
    Black Horse ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
    AGE LEVEL :14 and up
    SKILL LEVEL :intermediate
    BUILD TIME :6+ hours
    Model Scale 1:6 Scale
    Wingspan 1780mm / 70.0in
    Length 1520mm / 59.8in
    Weight 5500g / 13lbs
    CG (Center of Gravity) 100mm from the leading edge of the wing at the root
    Wing Area 51.9dm2
    Wing Loading 115.6 g/dm2
    Power System 295Kv Brushless Outrunner Motor or 20-26cc / 4-stroke (required)
    Electronic Speed Control 80A (required for electric)
    Propeller / EDF 19x8 for electric, 16x10 gas (required)
    Servos
    • Electric - 8x 45g standard (required) - we recommend MKS DS1220
    • Gas - 8x 45g standard as above (required) plus - we recommend HS-562MG
    Landing Gear CNC machined oleo gear (tri-gear)
    Required Battery TWO 4 Cell 14.8V 4000-5000 mAh LiPo Batteries with EC5 connector in series (required for electric)
    Required Radio 6+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights Optional
    Hinge Type Nylon Heavy Duty pin hinges
    Material Balsa and plywood
    Skill Level Intermediate
    Build Time 6+ Hours
  • Wulfman190
    • Mar 2022
    • 5
    I have had 2 of the 68” Phoenix Fw190’s that are great flying planes but I would love to try one of these ,because of the Blackhorse quality but it is nearly 2 hundred dollars more than the Phoenix . I will buy one eventually but for now I’ll wait to see if they put it on sale I’ll make sure to do a review when I do get one.
    • Wulfman190
      • Mar 2022
      • 5
      it’s a really nice looking plane the gear are a little short but it looks like a Focke wulf ! I lost mine today .I had done some modifications to use a NGH 30cc 4 stroke which was pretty marginal on power for this plane . I stalled it and it went in hard !so I’m here to order another.
      • colemn615
        • 15
        What did you have to do to get a 30cc. Looking at the weight I would think a 20cc isn't quite enough or is on the lower end and a 30cc would be great.
