Official Black Horse 2300mm Junkers Ju 87 B-2 Stuka ARF Thread
    • 8228
    Junkers Ju 87 B-2 Stuka 2300mm (90.5") Wingspan from Black Horse - Balsa Wood ARF - BHM1013-001
    The Junkers Ju 87, commonly known as the "Stuka", was a highly recognizable German dive bomber and ground-attack aircraft. Making its first appearance in 1937, it played a crucial role for the Axis powers throughout World War II. One of its most distinctive features was its inverted gull wings. Additionally, the aircraft was equipped with ram-air sirens called Jericho trumpets on its faired main gear legs, which came to symbolize German air power and the famous Blitzkrieg campaigns of 1939-1942.
    The Stuka was also equipped with innovative automatic pull-up dive brakes on both wings, ensuring a safe recovery from a dive even if the pilot experienced high g-forces or became too focused on their target. While it was a reliable and effective weapon against ground targets, the Stuka, like many other dive bombers of its time, was vulnerable to enemy fighter aircraft.
    The Black Horse Stuka is scaled to approximately 1:6 and attention was paid to a true to original appearance and favorable flight characteristics. The model can be operated using an electric power system or with an internal combustion engine about 60cc displacement.
    Scale Simulated Covering
    The printing and covering on the Ju 87 Stuka has scale rivet and panel line detail that elevates the model to a whole new level of scale appeal.
    Robust Landing Gear
    Aluminum oleo suspension struts absorb rough landings on grass surfaces while the iconic giant wheel pants provide additional protection from the elements.
    Gas or Electric Power
    You can choose between gas or electric to power your model depending on your preference. Check the specifications for recommendations.
    Large Wingspan
    This giant scale Ju 87 Stuka has an impressive 90.5" wingspan for impressive presence both in the air and on the ground.
    Removable Main Wing
    Easy assembly and intuitive design allows for the main wing to be removed for transport.
    Detailed Cockpit and Pilot
    The painted pilot and detailed cockpit provides that extra layer of scale detail that is sure to impress during states of static display.
    • Oleo CNC suspension metal struts
    • Lightweight, strong, laser cut balsa and plywood construction
    • Panel lines and details printed directly onto the pre-applied, high quality covering
    • Aerofoiled tail surfaces
    • Recessed hinges on all control surfaces
    • Pre-drilled hinge mounting holes
    • Heavy-duty pin hinges on all control surfaces
    • Large easy access fuel tank/battery/servo access hatches with sprung loaded latches
    • Painted and detailed cockpit, pilot and interior included
    • Fiberglass control horns with ball link connector
    • Two-piece, plug-in wings simplify transportation and assembly
    • Fiberglass cowl and glass reinforced landing gear covers/pants
    • Black Horse Junkers Ju 87 B-2 Stuka 2300mm (90.5") Wingspan - ARF
    • Instruction manual
    Requires (Electric):Requires (Gas):Customer Note
    Black Horse ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
    AGE LEVEL :14 and up
    SKILL LEVEL :intermediate
    BUILD TIME :6+ hours
    Model Scale 1:6 Scale
    Wingspan 2300mm / 90.5in
    Length 1837mm /72.3in
    Weight 8999g / 19.8lbs
    CG (Center of Gravity) 128mm from the leading edge of the wing at the root
    Wing Area 90.2dm2
    Wing Loading 95.34 g/dm2
    Power System 180Kv Brushless Outrunner Motor or 60cc 2 or 4-stroke (required)
    Electronic Speed Control HV 120A (required for electric)
    Propeller / EDF 22x12 for electric, 22x8 for gas (required)
    Servos
    • Electric - 9x 45g standard (required) - we recommend MKS-DS1220
    • Gas - 8x 45g standard as above (required) plus - we recommend HS-562MG
    Landing Gear CNC machined oleo gear (tri-gear)
    Required Battery TWO 6 Cell 22.2V 5500-6000 mAh LiPo Batteries with EC5 connector in series (required for electric)
    Required Radio 6+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights Optional
    Hinge Type Nylon Heavy Duty pin hinges
    Material Balsa and plywood
    Skill Level Intermediate
    Build Time 6+ Hours
  • MVidalFalcon
    • Feb 2024
    Hi, is there enough room in fuselage for a 12s setup? Looking to use 2 6s 5000
