Official Nexa 2020mm F8F Rare Bear ARF Thread
  • Official Nexa 2020mm F8F Rare Bear ARF Thread
    Click image for larger version  Name:	master.jpg Views:	45 Size:	197.1 KB ID:	401791
    F8F Rare Bear 2020mm (80") Wingspan - ARF from Nexa - NXA1066-001
    The discovery of Rare Bear, or the revamped Bearcat, was the result of Lyle Shelton's determination in 1969. Previously a wreckage found in Indiana, Rare Bear was once a victim of a failed throttle-on torque roll in 1962. Through relentless searching, Shelton acquired a stripped-down fuselage, wing center section, landing gear, and a right wing panel. With admirable efforts, the pieces were transported and restoration began in Orange County. Notably, the rebuild entailed upgrading to a more potent Wright R-3350 engine from a Douglas Skyraider, and utilizing a Douglas DC-7 propeller and cowl. Further support came from borrowing landing gear fairings and doors from another damaged Bearcat, and obtaining a rudder from Gunter Balz. The finishing touches, such as the windshield and canopy, were graciously provided by Edward T. Maloney. The first flight after the rebuild occurred on September 13, 1969.
    The Nexa Rare Bear is a .40cc size electric or gas option scale series warbird/racer with a 2020mm wingspan, constructed primarily from balsa wood and covered with a fuel-resistant covering. This ARF requires assembly and installation of your choice of servos and power system, and includes painted pilot and other scale details. The large battery hatch affords ample room for either electric or gas setups. Impress at your flying field with this iconic stunner!
    Large Battery Hatch
    The Nexa Rare Bear includes a large battery hatch for easy access to your battery and periphreal electronics.
    Scale Details Throughout
    The Rare Bear comes with a painted pilot and functional gear door that can be servo-operated.
    Prehinged and Installed Control Surfaces
    All control surfaces come out of the box fully prehinged and installed for your convenience.
    Impressive Size
    The Nexa Rare Bear has a robust presence with a near 80" wingspan.
    Features:
    • All Balsa and lite-ply construction
    • Large battery hatch for easy access
    • Fully covered in weathered detail
    • Fiberglass cowling
    • Painted pilot (installed)
    • Control surfaces pre-hinged and installed
    • Two piece wing with 2x Aluminum Wing Joiner
    • Gear door opens/closes by servo
    Includes:
    • Nexa F8F Rare Bear 2020mm (80") Wingspan - ARF
    • Assembly instructions with stage photos
    • Tail wheel assembly
    • Fiberglass painted pilot
    • Fuel tank for Gasoline
    • Wheels and wheel covers
    • 2x Aluminium wing joiner
    • Decals and all hardware
    Requires:Gas Requires:Customer Note
    Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
    AGE LEVEL :14 and up
    SKILL LEVEL :intermediate
    BUILD TIME :6+ hours
    Model Scale 1/6.6
    Wingspan 2020mm / 79.5in
    Length 1590mm / 62.6in
    Weight 7.8kg / 17.2-17.8lbs
    CG (Center of Gravity) 152-162mm from the leading edge of the wing's root
    Power System 2700W brushless outrunner motor or 35cc gas engine (required)
    Electronic Speed Control 85A (required)
    Propeller / EDF 19x10 2-blade for electric, 19x10 gas (required)
    Servos
    • 8x standard servos for ailerons, elevator, rudder and steering - HRC6005-012
    • 1x micro servo for throttle (gas) - HRC32225S
    Landing Gear Electric retractable tri gear (required)
    Required Battery TWO 6 Cell 22.2V 4000 - 5000 mAh LiPo Batteries (required)
    Required Radio 8+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Hinge Type Nylon
    Material Balsa and light plywood
    Skill Level Intermediate
    Build Time 6+ Hours
    US:
      Got the plane haven't removed it from the box yet just noticed description says their are no flaps but the Pic on the web of the plane shows flaps is the plane I purchased the same place e depicted on the site?
        I chatted with Motion support about the Aichi not matching the description and I was linked to the section 3 of the website TOS that basically says motion rc can put anything on the website and it does not need to accurate. Motion has become a Joke.
          It has flaps
