E flite T-28 Trojan 1.1 safe select switch trouble with radiomaster zorro
  • Weezerj
    • May 2024
    • 3
    Hi all, kind of new and having some difficulty with t-28 1.1 bnf.
    I am boud in safe mode fine to transmitter, but can't seem to figure out how to assign safe mode to a switch. Watched a few thousand videos, seems pretty straight forward...but doent work for me.
    I bound ar631 receiver to my zorro in safe mode (plane moves control surfaces twice to let me know in safe)
    With rates at 100%, no expo and no channels inverted, i get -100 to 100 output for throttle, rudder, aileron, and elevators.
    Next I try to tell receiver which switch I want to activate for safe. Procedure at HH is to put both sticks down and towards the center, the toggle switch you want 5 times. Afterwards you should get control surface wiggle. I don't get any reaction from plane when I do this procedure.
    From this point on, nothingnothinchanges the safe mode
    Any help would be greatly appreciated.
    JD
  • Weezerj
    • May 2024
    • 3
    Got it. (delete if desired).
    Had to reverse ailerons and rudder for receiver to see switch as activator. (link to source below)
