Official 450mm Model 220 with Gyro Thread
    Model 220 EPP with Gyro 450mm (17.7") from Skynetic - (Ready-To-Fly) - RTF - SKY1061-001
    The Skynetic Model 220 is a T-tail prop-driven civilian sport scale model for beginners and for those who love civilian aircraft but need to get their feet wet before exploring the larger, heavier, faster versions. Built with highly damage-resistant EPP foam, these micros go the extra mile to ensure a level of safety and confidence not commonly found with other types of foam. A great introductory model plus an entertaining adventure for those with plenty of R/C flying experience as well. So whether you are a newcomer to the hobby or a seasoned vet, the Skynetic Model 220 hits all the right notes.
    Dedicated Stand for Ease of Storage and Static Display
    The Skynetic Messerschmitt ME-109 comes with the perfect stand to easily display and store your model proudly.
    Easy To Maintain
    The gearbox drive supports a quick and easy setup to easily maintain the parts including replacing the propeller.
    Full Line of Replacement Parts Available
    From the pushrods and control horns to the motor, control board and propeller, we have you covered with a complete list of spare parts.
    Easy To Add or Remove Landing Gear
    Adding or removing the fixed landing gear is incredibly easy to do based on your preference.
    • One of the nicest micro warbirds for beginners on the market
    • Replaceable motor mount and prop saver as well as flight control board, easy to repair if needed
    • Detachable main wing and landing gear, glue-free assembly, portable for outdoor flying
    • One Key LOITER Function: the plane will keep circling in a 20m diameter circle in any altitude with the press of a button
    • Equipped with 6-Axis high sensitivity Gyro for high-level stability
    • Three different flying modes (6G / 3D / Manual)
    • Different sensitivity options for beginner to expert
    • Auto-launch feature for easy hand launches, slow flight, and controlled agility
    • Reliable radio control distance up to 150 meters without loss of signal
    • Low battery indicator for Radio: when the radio battery is low, the radio will beep and flash
    • Throttle Protection: the throttle will not function when powering up until you turn the feature off for safety
    • Digital Trimming: easily trim your control surfaces for enhanced stability
    • Gear Box Drive: Propeller is driven by a gear box, efficient and easy maintenance
    • Quick-Charge USB charger will fully charge your 3.7V 500mAh battery in 40 minutes
    • High quality durable EPP material, built-in carbon fiber spar for support and crash resistance
    • Pre-applied decals makes the plane easy to be seen in the sky
    • Built-in Carbon Fiber strip inside wing and aileron / tail for precise control and strength
    • Optimized air-cooling design will keep your electronics safe from overheating
    • Dedicated stand for ease of storage and static display
    • Full line of replacement parts available
    • Skynetic Model 220 EPP with Gyro 450mm (17.7") Wingspan - RTF
    • 4CH 2.4GHz Transmitter
    • 2.4GHz Receiver
    • 1S 3.7V 500mAh 20C LiPo Battery
    • USB 5V Charger
    • Owner's Manual
    Requires:
    New to RC?  We can help!
    HELPFUL TIP: If you are new to radio control (RC) we recommend that you read through our RC resource known as our "Knowledge Blog". It's jam packed with helpful information for beginners including how to articles, support videos, a glossary of terms and much more. Click Here to go to our Knowledge Blog's Beginner Section. For further assistance, please do not hesitate to contact our Customer Support Team and one of our knowledgeable RC experts will be glad to assist you. Happy flying! Product Specifications:
    AGE LEVEL :14 and up
    SKILL LEVEL :Beginner
    BUILD TIME :15 minutes
    Model Scale N/A
    Wingspan 450mm / 17.7in
    Length 380mm / 14.9in
    Weight 75g / 2.64oz
    CG (Center of Gravity) Refer to the manual
    Power System 1023 Coreless Motor
    Electronic Speed Control N/A
    Propeller / EDF 4-Blade Propeller
    Servos 2g micro for aileron, 1.3g micro for elevator and rudder
    Landing Gear Removable fixed
    Required Battery 1S 3.7V 500mAh LiPo (included)
    Required Radio 4 Channel 2.4GHz (included)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Hinge Type Nylon Reinforced
    Material EPP Foam
    Skill Level Beginner
    Build Time 15 Minutes
  • lomcevak
    • Dec 2017
    • 3
