G'day chomlee,
If it came down down to a FMS 1400mm P-51 or the Corsair, I would recommend you to go the Mustang route and then, once you have mastered the Mustang get the F4U.
Speaking from my personal experience [and flygirl may well beg to differ:D] the Mustang has better overall flying characters.
Each machine has its failings.
However, I find the Mustang is much easier to handle on the ground then the Corsair and is easier to get in the air then the F4U.
The Corsair loops better in MHO but is not so easy to roll in a straight line. You need much more input on all the sticks to get the roll nice for the Corsair.
The Corsair is much more sensitive to CG change then the Mustang with a 5 to 10 millimetre change making for dramatic changes in the handling of the Corsair.
I have three Mustangs and all needed 146 grams in the nose to get the nominated CG.
I have had the ballast in the Mustangs come adrift and lodge all the way back in the fuselage [forty grams] and I did not detect any changes to the way the model handled. We all heard the very loud clunk as the ballast went back during a loop [mag wheel balance weights] and I stopped stunting and flew carefully for a couple of circuits wondering and looking for a problem.
When I finally found the lead, the CG worked out to be 130mm from the leading edge..twenty millimetres rearward. Do that with the Corsair and you will have a tiger by the tail!! Trust me on this one. A change of five millimetres rearward turns the F4U into a snappy unhappy model.
By the way, FMS have the CG wrong for the V3. 110mm was and is correct for the V2. The V3 is a totally different model and the right CG is 90/95 millimetres. I have one of each V number.
All FMS models float when landing [try the Zero on for size:p] so I put a bit of nose down trim for landing.
I would recommend the P-51 over the F4U for your first foray into the machines.
I personally think that the FMS P-51 is superior to the FMS Trojan as a first warbird model.
I can speak only for the FMS 1400mm range and I would go in order of best to worst first birds, remembering that ALL the FMS machines fly nicely. This is based off my hanger and what I have flown.
P-51, T-28, Zero [maybe in front of the Trojan], F4U V3, F4U V2, FW190, P-38 and last is the Bf109. The 109 is NOT a first choice warbird. Absolutely fantastic in the air but a super duper handful on the ground.
I could give you a run down on all the models that I have but it will be a very long post over a couple of days.:D But I will do it if you would like me to.
Regards and respect
Daryl
Regards and respect
Daryl
