Official Nexa 1770mm T-28 Trojan Camo ARF Thread
    • 8228
    T-28 Trojan Camo 1770mm (69") Wingspan - ARF from Nexa - NXA1056-003
    This Nexa T-28 Trojan is available in a camo livery, featuring a large interior hatch to enable convenient access with either electric or gas power. Incredible scale details including a full figure pilot and detailed cockpit make the T-28 Trojan an optimal selection in any hangar.
    • Complete Balsa and lite-ply construction for rigidity and durability
    • Full figure pilot and detailed cockpit
    • Covered from tip to tail in scale details
    • Large battery hatch allows for your chosen electric or gas setup
    • Nexa T-28 Trojan Camo 1770mm (69") Wingspan - ARF
    • Landing gear and wheels
    Requires:Gas Requires:Optional:
    • Electric retractable tri gear with struts (not included) - NXA1506-118
    Customer Note
    Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
    AGE LEVEL :14 and up
    SKILL LEVEL :Intermediate
    BUILD TIME :6+ Hours
    Model Scale 1/7
    Wingspan 1770mm / 69in
    Length 1350mm / 53.1in
    Weight 5500g / 194oz
    CG (Center of Gravity) 126mm from the leading edge of the wing's root
    Power System 400Kv or equivalent brushless outrunner motor for electric or 2-stroke for gas (required)
    Electronic Speed Control 65A (required)
    Propeller / EDF 14x8.5 2-blade for electric or 14x8 2-blade for gas (required)
    Servos
    • 6x 45g standard servos: left aileron, right aileron, left elevator, right elevator, nose gear, rudder - HRC6005-024
    • 4x17g standard servos: left flap, right flap, left gear door, right gear door - HRC6005-028
    Landing Gear Fixed (included)
    Required Battery 6 Cell 22.2V 5000 - 6000mAh LiPo Battery (required)
    Required Radio 8+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights No
    Hinge Type Nylon
    Material Balsa and light plywood
    Skill Level Intermediate
    Build Time 6+ Hours
    • 8228
