Official Nexa 1580mm P-51B Tuskegee Airmen ARF Thread
    • 8228
    P-51B Tuskegee Airmen 1580mm (62.2") Wingspan - ARF from Nexa - NXA1058-001
    The P-51B Mustang, powered by the Merlin engine, was introduced in 1943 and was heralded by Allied bombers in Europe for its impressive long-range and powerful high-altitude escort capability. Among the US fighters of WWII, the P-51 Mustang is one of the most widely known. The Red Tail scheme was made famous by the incomparable Tuskegee Airmen who were the first African American soldiers to successfully complete their training and enter the Army Air Corps and became widely regarded as some of the finest pilots of the entire war.
    This Nexa P-51B Mustang is a electric or gas option .46-size aerobatic airplane with a 1580mm wingspan, constructed primarily from balsa wood and covered with a fuel-resistant covering. This ARF requires assembly and installation of your choice of servos and power system, and includes fully functional flaps, fiberglass cowl, painted pilot and other scale details. The large battery hatch affords ample room for either electric or gas setups. Impress at your flying field with this iconic World War II warbird!
    Fully Covered and Detailed
    The Nexa P-51B comes fully covered including simulated panel lines and rivets.
    Scale Details Throughout
    There is no shortage of scale details with this P-51B Mustang including functional flaps, detailed cockpit and painted pilot.
    Easy Battery Access
    The battery hatch is ingeniously accessed through the side of the fuselage for easy access.
    Fly An Allied Classic
    The P-51B Mustang Red Tail is an iconic American WWII warbird that performs aerobatics with ease and style.
    • Complete Balsa and lite-ply construction for rigidity and durability
    • Covered from tip to tail in scale details including functional flaps, plastic seat, antenna, printed simulated panel lines and rivets
    • Fiberglass cowling for strength and durability
    • All control surfaces come out of the box pre-hinged and installed for convenience
    • Large battery hatch allows for your chosen electric or gas setup
    • Nexa P-51B Tuskegee Airmen 1580mm (62.2") Wingspan - ARF
    • Wheels and spinner
    • Fuel tank, hardware and decals
    Requires:Gas Requires:Customer Note
    Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
    AGE LEVEL :14 and up
    SKILL LEVEL :intermediate
    BUILD TIME :6+ hours
    Model Scale 1/7.5
    Wingspan 1580mm / 62.2in
    Length 1190mm / 46.8in
    Empty Weight 3100g / 109.34oz
    CG (Center of Gravity) 132mm from the leading edge of the wing's root
    Power System 580Kv or equivalent brushless outrunner motor for electric or .46 - .70 (7.45cc - 11.5cc) for gas (required)
    Electronic Speed Control 70-85A (required)
    Propeller / EDF 13x8 2-blade for electric or 12x6 2-blade for gas (required)
    Servos 45g metal gear standard: left aileron, right aileron, elevator, rudder - HRC6005-017
    17g metal gear standard: left flap , right flap - HRC6005-022
    Landing Gear Electronic retractable gear (required)
    Required Battery 6 Cell 22.2V 4000 - 5000mAh LiPo Battery (required)
    Required Radio 6+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights No
    Hinge Type CA fabric
    Material Balsa and light plywood
    Skill Level Intermediate
    Build Time 6+ Hours
