E Flite Apprentice climbs too much
  • Seabear1500
    • Feb 2025
    Back in the hobby after 30 years so I bought an Apprentice to start. After 15-20 flights I’m feeling good and flying in advanced mode. The only issue I have is that it still wants to climb when the throttle is over 50%. Climbs out of sight on full throttle if you let it.
    Elevator trim doesn’t solve it because when you back off the throttle it’s in a nose down attitude.
    i tried adding washers to increase downward thrust on the motor but that’s not enough. Should I add more or is there a radio adjustment I can make?
