I received my Freewing P-51 earlier in the week, and built it the same day (a quick build for sure). Although I have built, owned, and flew many of the park flyer sized foamies, and found good planes in the Dynam, FMS, Airfield brands, I've only had two Freewing planes to date. Both were very good builds with great components, nice attentions to detail, and quick and easy assembly. This new 6 channel P-51 with sound module (granted it doesn't sound like a Merlin, but it's much better than no sound at all) and innovative landing lights, sliding canopy, flashing LEDs, a great landing gear sequencer module, among other perks and well thought out items such as ball clevis linkage rod ends, set screw adjusted at the servo ends and much more is without a doubt one of my favorite electrics at this time. It flys with very good control, floats in with very stable landings (I crank in a high degree of flap on all of my warbirds) but here is my main reason for this posting. Although the manufacturer states battery needs are a 1000 MAH 3s for the sound module, and a 2200 MAH 4s batt for power, I used what I had being a 1300 MAH 3s (at 110 grams weight) for the sound module, and my trusty 3300 MAH 4s batts (at 385 grams weight) for power and the plane balanced perfectly! I don't have the recommended smaller batts for comparison, but would think they are too light (forget about being to low of a MAH) to achieve the proper CG. All I am saying is to be wary of your CG with this plane, as what I used, and flew was spot on perfect for the task. Also before signing off I would like to comment on this planes wheels and gear. I fly off of a very well manicured grass club field that friends with some Parkzone warbirds (among other brands) don't do well with, but this Freewing P-51 with it's suspension Oleo legs, and nice sized block treaded tires did as well as my gas giants on takeoffs and landings. I can highly recommend this plane to intermediate and accomplished low wing pilots.
Ed (Warbidaholic) out!
