New AeroTetris models
  • qwerty1000
    • May 2025
    • 22
    Hello Friends!
    I think these models will be interesting here?
    New Model Lockheed C-130 Hercules
    С-130A/E/H/J/H30
    Wingspan - 3077mm
    Length - 2200/2250/2600mm
    Wing area - 87.6dm²
    Reference area (S): - 104.86dm²
    Reference length (lm): - 356.4mm
    CG (16%): - 874.0/923.8/1126.0mm
    CG (8%): - 902.5/952.3/1154.5mm
    AC: - 931.0/980.8/1183.0mm
    Number of components - 754pc
    CNC cutting length - 490876mm
    Weight glued full - 2460gr
    Best Regards, Egor
    • 4820
    Very interesting.
    Best, LB
    • qwerty1000
      • May 2025
      • 22
      AeroTetris Model F14 Tomcat 2700
      Wingspan - 2800/1690mm
      Length - 2700mm
      Wing area - 70.52dm²
      Reference area (S): 211.92/170.40dm²
      Reference length (lm): 234.2/323.3mm
      CG (16%): 1630.5/1651.4mm
      CG (8%): 1649.3/1677.3mm
      AC: 1668.0/1703.1mm
      Number of components - 1230pc
      Number of weapons parts - 200pc
      CNC cutting length - 486520 mm
      Weight glued full - 2925gr
      For 2x120mm EDF/JET
      - The kit includes a 3d model of the wing turning mechanism for you CNC router.
      - The CAD/CAM files of the wing turning mechanism are not sold separately from the kit.
      - The wing turning mechanism follows the internal structure of the fuselage.
      - We recommend using reinforced servos HP200/400 Plus (for Large version), or their equivalents.
      - You choose the servo rods yourself, based on your tasks.
      The set includes weapons made in 1/7 scale
      AIM-9 Sidewinder - 2pc
      Length - 430мм
      Diameter - 18мм
      Wingspan - 40мм
      AIM-54 Phoenix - 2pc
      Length - 570мм
      Diameter - 55мм
      Wingspan - 132мм
      GBU-12 - 4pc
      Length - 467мм
      Diameter - 40мм
      GBU-31 - 2pc
      Length - 543мм
      Diameter - 50мм
      Wingspan - 90мм
      AN/AAQ-14 LANTIRN - 2pc
      Length - 357мм
      Diameter - 54мм
      External tank - 2pc
      Length - 571мм
      Diameter - 80мм
      GBU-24 - 2pc
      Length - 617мм
      Diameter - 53мм
      AIM-7 Sparrow - 2pc
      Length - 530мм
      Diameter - 30мм
      Wingspan - 115мм
        • 4820
        qwerty1000
        You recommend PVA glue for the assembly right?
        In any event, ingenious part design, concept, and outcome.
        Best, LB
        • qwerty1000
          • May 2025
          • 22
          Originally posted by Elbee
          qwerty1000
          Best, LB
          Hello Elbee
          Yes, PVA glue
          Thanks
          Best Regards, Egor
          • qwerty1000
            • May 2025
            • 22
            AeroTetris Model JAS-39 Gripen 1800mm
            JET version
            Stewart build and flights
            Wingspan - 1028 mm
            Length - 1760 mm
            Wing area - 31.86 dm²
            Number of components - 317 pc
            CNC cutting length - 178650 mm
            Weight glued full - 490 gr
            For 1x120mm EDF
            One parcel 610x580x210mm
            Weight parcel 3000gr
            Shipping is not included in the price
            Shipping to any country for 3-20 days​
            • qwerty1000
              • May 2025
              • 22
              AeroTetris Model F-104G-2300 Starfighter Version 2
              Wingspan - 954 mm
              Length - 2327 mm
              Wing area - 25.2 dm²
              Reference area (S): 49.25 dm²
              Reference length (lm): 714.7 mm
              CG (16%): 1371.4 mm
              CG (8%): 1428.5 mm
              AC: 1485.7 mm
              Number of components - 478 pc
              CNC cutting length - 194538 mm
              Weight glued full - 2600 gr
              For 1x120mm EDF
              One parcel 610x600x210 mm
              Weight parcel 3000 gr
              • qwerty1000
                • May 2025
                • 22
                AeroTetris Model Lockheed SR-71-4100 Blackbird scale 1/8, version II
                Wingspan - 2224mm
                Length - 4100 mm
                Wing area - 169.46dm²
                Reference area (S): 219.45dm²
                Reference length (lm): 1440.6mm
                CG (16%): 2156.8mm
                CG (8%): 2272.1mm
                AC: 2387.3mm
                Number of components - 690pc
                CNC cutting length - 624540mm
                Weight glued full - 5425gr
                For 2x175mm EDF or 2xJET
                • qwerty1000
                  • May 2025
                  • 22
                  AeroTetris Model Horten Ho-229 - 3000
                  Frank build
                  Wingspan - 3136 mm
                  Length - 1433 mm
                  Wing area - 193.4 dm²
                  Reference area (S): 181.55 dm²
                  Reference length (lm): 667.0 mm
                  CG (16%): 500.6 mm
                  CG (8%): 553.9 mm
                  AC: 607.3 mm
                  Number of components - 278 pc
                  CNC cutting length - 252540 mm
                  Weight glued full - 2180 gr
                  For 2x90mm EDF
                  • qwerty1000
                    • May 2025
                    • 22
                    AeroTetris Model English Electric Lightning F6 - 2550
                    Wingspan - 1875mm
                    Length - 2550mm
                    Wing area - 112,2dm²
                    Reference area (S): 132.78dm²
                    Reference length (lm): 802.7mm
                    CG (16%): 1331.7mm
                    CG (8%): 1395.9mm
                    AC: 1460.1mm
                    Fuel tanks and weapons:
                    Firestreak - 1pc
                    Red Top - 1pc
                    Number of components - 756pc
                    CNC cutting length - 468580mm
                    Weight glued with fuel tanks and weapons set - 2780gr
                    Weight glued without fuel tanks and weapons set - 2320gr
                    For 1x120mm EDF or
                    2x90/100/110/120mmEDF​
                      • 4820
                      Qwerty,
                      I would like to make a suggestion that could help your marketing.
                      Contact Aros here at Hobby Squawk and ask if you can post your business in the "Banner Advertising" section.
                      If you look at the top of each web page, there is a horizontal banner ad space.
                      If Aros approves of your product and ad, you will be able to advertise for "Free" in that location.
                      I highly recommend you contact Aros through a Private Message and request permission.
                      Best, LB
                      • qwerty1000
                        • May 2025
                        • 22
                        Qwerty,
                        Best, LB
                        Gracias Elbee!
                        • qwerty1000
                          • May 2025
                          • 22
                          Model F4D Skyray - 1600
                          Gerry's build and flights
                          Wingspan - 1290 mm
                          Length - 1580 mm
                          Wing area - 70.4 dm²
                          Reference area (S): dm²
                          Reference length (lm): mm
                          CG (8%): 1241 mm
                          CG (4%): 1275 mm
                          AC: 1310 mm
                          CNC cutting length - 212654 mm
                          Weight glued full - 940 gr
                          For 1x90mm EDF
                            • 8749
                            I'm sorry, but the free banner is the way to go. This is now SPAM!
                            • qwerty1000
                              • May 2025
                              • 22
                              Hello Xviper!
                              I have taken note of your comment.
                              I currently have several models in development, including the VIPER JET - 2800 (Length-2800mm)
                              Best Regards, Egor​
                                • 5385
                                It's way more interesting than pages and pages of alternative motor windings.
                                  • 8749
                                  So true! What's up with that anyway?
                                  Forget my comment qwerty, post away. At least you're not talking to yourself for thousands of posts about something almost nobody cares about or understands.
                                  BTW, I've known about your kits for many, many years. Almost bought one. They're just too complicated and too many parts to suit my patience level.
                                  • qwerty1000
                                    • May 2025
                                    • 22
                                    Model F4D Skyray - 2000
                                    Robin build and flight
                                    Wingspan - 1613 mm
                                    Length - 1976 mm
                                    Wing area - 88 dm²
                                    CG (8%): 1241 mm
                                    CG (4%): 1275 mm
                                    AC: 1310 mm
                                    CNC cutting length - 248567 mm
                                    Weight glued full - 1480 gr
                                    For 1x120mm EDF
                                    One parcel 610x590x310mm
                                    Weight parcel 4000gr
                                    • qwerty1000
                                      • May 2025
                                      • 22
                                      Tony build
                                      Wingspan - 3136 mm
                                      Length - 1433 mm
                                      CG (16%): 500.6 mm
                                      CG (8%): 553.9 mm
                                      AC: 607.3 mm
                                      For 2x90mm EDF
                                      • qwerty1000
                                        • May 2025
                                        • 22
                                        Model SAAB-105-1900mm
                                        Thomas build and flight
                                        Wingspan - 1684 mm
                                        Length - 1892 mm
                                        Wing area - 32.7 dm²
                                        Number of components - 250pc
                                        CNC cutting length - 142893 mm
                                        Weight glued full - 990 gr
                                        For 2x90mm EDF
                                        One parcel 630x580x210mm
