Reflex V3
  • Nomes
    • Jun 2025
    • 14
    Reflex V3
    Can a Reflex V3 be laid on its side and or rotated 1/4 turn or does it have to be laid flat on it's back?
    • 5401
    Either as long as you change the settings.
    • Nomes
      • Jun 2025
      • 14
      What do you mean (change the settings and how?
        • 5401
        Read the instructions for it.
        • oliojam
          • Jun 2025
          Originally posted by geometry dash lite
          ​Can a Reflex V3 be laid on its side and or rotated 1/4 turn or does it have to be laid flat on it's back?
          Yes, the Reflex V3 can be laid on its side, but airflow and cable orientation might be affected depending on your setup.
            • 5401
            That can be said for any orientation.
            • Nomes
              • Jun 2025
              • 14
              Tried to lay it on the side didn't work for me.
                • 5401
                What didn't work?
                  • 5401
                  It isn’t a bad gyro as long as it’s programmed right. When it comes in a plane it works okay. If you buy one from stock or used it has to be programmed as I said is post #2 of this thread.
                  • Nomes
                    • Jun 2025
                    • 14
                    Rexlex V3 didn't work for me on it's side.
                      • 5401
                      What didn't work?
                      What didn't work?
                      • Nomes
                        • Jun 2025
                        • 14
                        When it came in my plane it was upside down. The only thing was the plane could have been desinged a little better.
