Official Skynetic 1500mm XCub PNP Thread
    • 8230
    XCub 1500mm (59.1") Wingspan - PNP from Skynetic - SKY1069-001
    A modern take on the classic bush plane, the Skynetic XCub blends rugged versatility with clean lines and a striking full-scale-inspired paint scheme. Sporting a 1500mm wingspan, this model delivers stable flight characteristics with excellent STOL capability, making it a perfect match for club fields, grass strips, and backcountry-style flying.
    Factory-finished in a high-contrast blue, silver, and white livery, the XCub is molded from lightweight EPO foam and arrives nearly ready to fly – simply add your receiver and flight battery and you’re all set. The tall taildragger stance, oversized tundra tires, and scale landing gear geometry provide confident handling on rough terrain and short runways alike.
    With its powerful 3541-750Kv brushless motor the XCub delivers incredible performance on 4S power and smooth, predictable handling in a wide flight envelope. Whether you're into scale flying, high performance aerobatics, or backcountry-style touch-and-gos, the Skynetic XCub is ready for adventure!
    Striking Full-Scale Inspired Scheme
    Finished in a bold blue, silver, and white livery for standout visibility and realism.
    Built for the Backcountry
    Oversized tundra tires and taildragger stance handle rough terrain with ease.
    Reverse Thrust Ready
    Pre-programmed reverse thrust lets you stop on a dime and nail short landings.
    Adventure-Ready Power
    750Kv motor and 11x7 prop deliver incredible performance and flight times on a simple 4S battery.
    Tow Hook Included
    Built-in, servo actuated tow release adds versatility—tug gliders or explore aerotow flying.
    Quick Field Setup
    Detachable wings and tail make transport easy and setup fast at any flying site.
    Features:
    • Lightweight, durable EPO foam construction with factory-applied graphics
    • 1500mm (59.1") wingspan for excellent stability and presence
    • High contrast blue, silver, and white scale-inspired color scheme
    • Oversized tundra tires absorb bumps and handle rough fields with ease
    • Pre-programmed reverse thrust allows ultra-short landings in tight spaces
    • Detachable wings and tail for easy transport and quick field setup
    • Oversized control surfaces and functional flaps for STOL capability
    • Built-in, servo actuated tow hook enables glider tug operations right out of the box
    • Powerful 3541-750Kv motor and 40A ESC deliver thrilling 4S performance
    • Spacious battery bay fits 4S 2200–3300mAh LiPo packs for flexible flight times
    • Easy-access magnetic hatch simplifies battery changes at the field
    Includes:
    • Skynetic XCub 1500mm (59.1") Wingspan – PNP
    • Factory-installed 3541-750Kv brushless outrunner motor
    • Factory-installed 40A brushless ESC with pre-programmed reverse thrust option
    • Factory-installed servos on all surfaces
    • Factory-installed glider tow hook
    • Scale-style landing gear and large, air-filled tundra tires
    • Illustrated instruction manual
    Requires:
    • 6-7 Channel radio (7 required for thrust reverse & glider tow hook functions) - select a minimum 6 channel radio from our Aircraft Radio Collection
    • 6-7 Channel receiver (7 required for thrust reverse & glider tow hook functions) - select a minimum 6 channel receiver from our Aircraft Receiver Collection
    • 4-cell 2200mAh to 3600mAh LiPo battery with XT-60 connector - We recommend the Admiral 4 Cell 14.8V 2500mAh Pro LiPo battery
    • 4 Cell compatible battery charger - select a minimum 4 cell (4S) charger from our Charger Collection
    • Small bicycle type air pump to inflate the air filled tundra tires
    Product Specifications:
    AGE LEVEL :14 and up
    SKILL LEVEL :Intermediate
    BUILD TIME :30 Minutes
    Model Scale 1/7
    Wingspan 1500mm / 59.1in
    Length 1080mm / 42.5in
    Weight 1.6kg / 3.5lbs
    CG (Center of Gravity) Refer to manual
    Power System 3541-750Kv Brushless Outrunner Motor (included)
    Electronic Speed Control 40 amp brushless ESC factory programmed for reverse thrust (included)
    Propeller / EDF 11x7 Electric (included)
    Servos 5x9g, 2x17g (included)
    Landing Gear Fixed taildragger with oversized tundra tires (included)
    Required Battery 4-cell 2200mAh to 3600mAh LiPo battery (required)
    Required Radio 6-7 Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights N/A
    Hinge Type Foam
    Material EPO Foam
    Skill Level Intermediate
    Build Time 30 minutes or less
    Recommended Environment Outdoors (grass, dirt, or pavement runways)
  • stitch
    • Dec 2014
    • 142
    Got a set of floats fit right on this plane! Wonder how it fly with some on it!
    • stitch
      • Dec 2014
      • 142
      Guess I get one try em!🤣
        • 8230
        Give it a go!
        • Dcnbear
          • Jun 2021
          Anyone know what floats to use in this X Cub?
