Avios Spitfire Mk1a to Prototype conversion
  • Avios Spitfire Mk1a to Prototype conversion
    Hi all, I decided to build up my spare Avios Spitfire Mk1a into the Prototype version.
    Still a work in progress but the majority of the work has now been done.
    I had to make new cockpit canopy parts to match the original plane, was easy enough to do and I used the clear plastic from an Easter Egg packaging I save from last year! I knew it would come in handy at some point!
    Flipped the wheels around so the flat side was facing outward as the prototype appears to have had covers over the wheels.
    Also had to make a set of the flush fitting exhaust stacks, I used balsa wood sections painted black as the backing and the clear plastic with holes punched out for the exhausts and paintes them the same colour as the plane.
    So now there is just a few small things to do such as paint the prop and spinner and to find a sticker set for it. I have reached out to Callie Graphics but if anyone has any ideas or options I could go with for the markings I would greatly appreciate it as the turn around time for Callie Graphics has proven very slow in the past.
    I also wanted to have the skid type tail wheel setup like the prototype had but when I did some taxi tests, the plane didn't respond well to the skid and was difficult to control. So I refitted the tail wheel.
    I also trimmed up the landing leg fairings for better ground clearance and to prevent damage if the plane noses over. I won't be attempting the fully enclosed fairings like the prototype had as it will be too complicated to achieve and to ensure reliable operation.
    I have attached some photos of the build process.
    Hope you like it!
    Looks great! Good idea for a project.
    (Dangerous Dan)
      Painted the prop today!
        Awesome, how does that affect the CG?
          CG is basically the same as the stock version.
            So pretty much done for now, just waiting on a sticker set from Callie Graphics, but that will take at least a month or more.. unless I find something else in the meantime.
              Done a few more small details, paintes over the white parts of the lower landing gear legs to silver to match the upper strut. Painted the gun bullet casing ejection ports black and replaced the prop with an APC prop as the original one paint kept reacting and frying up.
              Yes the new prop is a heavy pattern prop but it works fine and doesn't pull too many amps over the maximum rating, besides I'll never use wide open throttle anyway.. And I didn't paint the tips yellow on this one as the original prototype never had the yellow tips. Only the replica prototype did.
              Sticker set has been ordered..
                Looks great Spanner, I love the fact that you replicated the original canopy as well, she should fly as good as she looks.
                (Dangerous Dan)
                  Thanks Dan! Yeah I was worried how the canopy would turn out but it was easier to do than I expected and looks pretty good.
                  I am certainly hoping the plane will fly well. Fingers crossed!
                    Repainted the spinner, I believe it is more accurate this way.
                    • #11
                      Wasn't happy with the APC pattern prop, the additional weight of it concerns me. So I stripped off all the paint from the Fiala wooden prop and refitted it. The APC prop weighs in at a hefty 126 grams! Compared to the Fiala wooden prop at only 38 grams! Huge difference!
                      Also ordered a second one as a spare.
                      • #12
                        So the Spitfire Prototype project is now complete. The sticker set from Callie arrived this morning and got them fitted up.
                        They aren't quite right, font and sizing aren't particularly accurate but they are good enough and I'm very happy with how it turned out.
                        Now to do the maiden flight!
