Official Black Horse 1880mm Edge 540 V3.2 Balsa Wood ARF Thread
    Edge 540 V3.2 1880mm (74") Wingspan from Black Horse - Balsa Wood ARF - BHM1011-001
    Version Info: This is the version 2 of the Edge 540 V3. Several upgrades include a striking new paint scheme, carbon fiber landing gear, carbon fiber wing spar and fiberglass carbon plywood has been applied throughout the entire model's structure.
    The Zivko Edge 540 manufactured by Zivko Aeronautics is a highly aerobatic aircraft. Capable of a 420 degree per second roll rate and a 3,700 foot per minute climb rate, it has been flown to victory on the international Unlimited aerobatics circuit several times since the mid-1990s. A tandem-seat version is sold as the Edge 540T.
    The Zivko Edge 540 is the most common aircraft used in the Red Bull Air Race World Series.
    Our model is scaled to approximately 1:5 and attention has been given to providing a realistic appearance with outstanding flight characteristics. The model was designed for electric power but can also be flown using a matched pair of internal combustion engines of about 35-38cc displacement.
    Bold, Eye-Catching Scheme
    The new version 2 of the Edge 540 V3 comes with a striking and bold paint scheme that is sure to represent well anywhere you choose to fly.
    New Carbon Fiber Struts
    The struts have been upgraded to carbon fiber for a superior blend of lightweight and strength.
    Upgraded Materials Throughout
    Fiberglass carbon plywood has been applied throughout the entire model's structure for improved strength and support.
    Electric or Gas
    You can choose your choice of power system from electric or gas setups to suit your personal preference.
    • NEW! Lightweight, strong, and fully sheeted laser cut fiberglass carbon plywood construction
    • NEW! Carbon fiber wing spar and landing gear struts
    • Covered in high quality Oracover
    • Recessed hinges on all control surfaces
    • Large easy access fuel tank/battery/servo access hatches with sprung loaded latches
    • Painted and detailed cockpit, pilot and interior included
    • Fiberglass twinned control horns with ball link connector
    • Pull-Pull control system on the rudder for precision control and authority
    • Two-piece, plug-in wings simplify transportation and assembly
    • Fiberglass cowl and landing gear covers/pants
    • Fully illustrated instruction manual included and also available for download (see tab above)
    • Black Horse Edge 540 V3.2 1880mm (74") Wingspan - ARF
    Requires (Electric):
    Requires (Gas):
    • Engine: 35cc 2-stroke (NGH GT35 recommended). 38cc 4-stroke (NGH GF38 recommended)
    • Gas Propeller: 18x10 - 20x8 (2 Stroke and 4 Stroke)
    Customer Note
    Black Horse ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Intermediate
    BUILD TIME : 6+ hours
    Model Scale 1/5 Scale
    Wingspan 1880mm / 74in
    Length 1850mm /72.83in
    Weight 5307-5443g / 11.7-12lbs
    CG (Center of Gravity) Refer to the owner's manual
    Power System 2500 Watt+ Brushless Outrunner Motor or 35cc 2 or 38 4-stroke (required)
    Electronic Speed Control 80+A (required)
    Propeller / EDF 20 x 8E to 21 x 10E 2 blade electric propeller (required)
    Servos
    • Electric - 5x 45g high torque (required) - we recommend HRC32625S
    • Gas - 6x 45g high torque (required) - we recommend HRC32625S
    Landing Gear Fixed
    Required Battery TWO 6S 22.2V 3500-5000mAh LiPo Batteries (required)
    Required Radio 6 Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights Optional
    Hinge Type Fiberglass
    Material Balsa and plywood
    Skill Level Intermediate
    Build Time 6+ Hours
