Official Skynetic 1320mm Altura RTF/PNP Trainer Thread
    • 8218
    Altura 1320mm (51.9”) Wingspan - RTF from Skynetic - SKY1070-001
    The Skynetic Altura 1.3m Ready-to-Fly RC Trainer & Sport Airplane is built to inspire confidence from your very first takeoff — and keep you smiling long after you’ve mastered the basics. Its high-wing design and stable handling make learning smooth and predictable, while its responsive control authority gives it the performance needed for true sport flying.
    The included multi-mode gyro stabilization system allows you to select Beginner, Intermediate, or Advanced flight modes. Start with self-leveling and angle limited stability as you build confidence, then transition into full manual control when you’re ready to explore aerobatics. Rolls, loops, and sport maneuvers are well within the Altura’s capability, making it far more than just a first airplane.
    Durable EPO construction and reinforced landing gear are designed to absorb the realities of training while maintaining crisp flight performance. Smart aerodynamic design improves low-speed handling and stall forgiveness, yet still allows the Altura to feel lively and responsive when pushed harder. A built-in motor safety cutoff system adds protection during setup and handling for added peace of mind.
    The RTF package includes everything needed to get airborne quickly, making the Altura an ideal first RC airplane — and a surprisingly capable sport model that grows right alongside you.
    Train Smart. Fly Bold.
    The Altura’s multi-mode gyro stabilization lets you start in Beginner mode and advance as your skills grow. Smooth corrections and predictable handling build confidence fast. When you're ready, unlock its full sport potential.
    From First Flight to Full Aerobatics
    Stable enough for training, capable enough for sport flying. Loops, rolls, and other aerobatics are all within reach once you move into Advanced mode. This isn’t just a trainer — it’s an airplane designed to grow with your skills.
    Ready the Moment You Are
    Everything you need is in the box — radio, battery, charger, and factory-installed electronics. Charge, assemble, and fly in minutes. No guesswork, no extra purchases, no complications.
    Built to Last
    Reinforced EPO construction shrugs off the bumps and hard landings that come with learning. The tricycle landing gear keeps takeoffs straight and landings forgiving. It’s made for real-world flying, not just perfect conditions.
    Smooth Power When You Need It
    The factory-installed brushless motor delivers strong, consistent thrust from takeoff to vertical climb. Cruise comfortably at partial throttle or push it harder when you're ready. It’s balanced power for both learning and sport performance.
    Confident Control At All Speeds
    The wing design provides excellent low-speed handling and reduced stall tendencies. Approaches feel steady and predictable, helping newer pilots land with confidence. Even experienced flyers will appreciate its smooth, stable glide.
    • 1.3m high-wing trainer and sport airplane designed for stability and growth
    • Ready-to-Fly package includes transmitter, battery, and charger
    • Multi-mode gyro stabilization system with Beginner, Intermediate, and Advanced modes
    • Self-leveling flight assistance with bank and pitch limits to keep the aircraft in safe attitudes and build confidence during early flights
    • Full manual control mode for aerobatic sport flying
    • Aerobatic-capable design with responsive control and excellent power to weight
    • Durable EPO foam construction built for training and everyday flying
    • Reinforced landing gear designed to absorb hard landings
    • High-lift wing design improves low-speed handling and stall forgiveness
    • Removable wing for convenient transport and storage
    • Factory-installed brushless motor for smooth, reliable performance
    • Pre-installed ESC and servos for simplified setup
    • Simplified design allows the aircraft to be assembled in under 30 minutes
    • Motor safety cutoff prevents accidental throttle engagement during setup
    • Stable ground handling characteristics for smooth takeoffs and landings
    • Long-lasting nylon hinges built for reliable performance
    • Skynetic Altura 1.3m Ready-to-Fly Trainer & Sport Airplane
    • Factory-installed brushless motor, ESC, servos, receiver, and multi-mode gyro stabilization system
    • 2.4GHz transmitter with beginner, intermediate, and advanced flight modes
    • 4s 2200mah flight battery and USB charger
    • Durable tricycle landing gear set
    • Propeller and spinner
    • Complete hardware pack and assembly accessories
    • Instruction manual
    AGE LEVEL : 14 and Up
    SKILL LEVEL : Beginner
    BUILD TIME : 30 Minutes
    Model Scale N/A
    Wingspan 1320mm / 51.9in
    Length 970mm / 38.2in
    Weight 1270g / 30 oz (w/o battery)
    CG (Center of Gravity) 60mm (2.36") as measured from the wing root leading edge aft
    Power System 4S 3536-850Kv Brushless Outrunner Motor (included)
    Electronic Speed Control 40A, XT60 Connector with power safety switch (included)
    Propeller / EDF 11x5 2-Blade Propeller (included)
    Servos
    • Elevator and Rudder – 17g Metal Gear Servo (SKY1070-120)
    • Aileron – 9g Metal Gear Servo (SKY1070-121)
    Landing Gear Fixed tricycle landing gear
    Required Battery 4S 14.8V 2200 mAh LiPo with XT60 connector (included)
    Required Radio 4 Channel (included)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Brakes No
    Gyro Yes
    Hinge Type Nylon
    Material EPO Foam
    Skill Level Beginner
    Build Time 30 Minutes
    Recommended Runway Surface Well manicured, short grass and hard surfaces
    • 8218
    PNP Version:
    Buy Skynetic Altura 1320mm (51.9") Wingspan - PNP online at Motion RC. Order online with fast delivery.
    • rampage
      • 45
      It's kind of adorable. Being a fan of trainers anyway, I might need one of these...
      Looks like it has slots for floats? Is there an official float set for it?
