Official Nexa 1618mm Fly Baby ARF Discussion Thread
    Fly Baby 1618mm (63.7") Wingspan - ARF from Nexa - NXA1060-001
    The Nexa Fly Baby ARF faithfully reproduces the classic Bower's Fly Baby, a beloved homebuilt aircraft renowned in the EAA community. Ready to assemble out of the box with all hardware included, it is the perfect introduction to this classic homebuilt aircraft.
    This Fly Baby is an ideal model for intermediate pilots looking for a fun, easy airplane for practice and recreational flying. The full size aircraft that inspired this model has been flown for air shows across the Midwest and its vibrant scale color scheme looks great in the sky. Experienced modelers will also find the Fly Baby easy and enjoyable to fly.
    Fully Covered in Weathered Detail
    The Nexa Fly Baby comes fully covered with an attractive blue and yellow livery with weathered detail for a more scale appearance.
    Scale Details Throughout
    Along with the fiberglass cowl, the Fly Baby has a painted cockpit, pilot, dummy radial engine and other scale details.
    Pre-Hinged and Pre-Installed Hinges
    All control surfaces and hinges come pre-hinged and pre-installed for your convenience, lessoning build time.
    Balsa and Lite-Ply Construction
    The Nexa Fly Baby is manufactured with balsa and lite-ply construction for a durable yet lightweight airframe for better performance.
    • Factory laser cut, jig-built
    • All balsa and lite-ply construction
    • Factory covered and finished
    • Hand painted pilot
    • Fiberglass cowling
    • Control surfaces pre-hinged and installed
    • Two piece wing with aluminum wing joiner
    • Molded dummy engine cylinders
    • Compatible with glow and electric power setups
    • Big battery hatch for ease of access
    • Easy-to-remove fuselage top cover
    • Complete hardware package
    • Nexa Fly Baby 1618mm (63.7") Wingspan - ARF
    • Assembly instructions with stage photos
    • Tail wheel assembly
    • Fiberglass painted pilot
    • Wheels, wheels cover
    • Aluminum wing joiner
    • Engine mounts
    • Spinner
    • Fuel tank
    • Decals and all hardware
    Requires:Gas Requires:Customer Note
    Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Intermediate
    BUILD TIME : 6+ hours
    Model Scale 1/5
    Wingspan 1618mm / 63.7in
    Length 1168mm / 45.9in
    Empty Weight 3000g / 105.8oz
    CG (Center of Gravity) 89mm from the leading edge of the wing's root
    Power System 770Kv or equivalent brushless outrunner motor for electric or .46 - .70 (7.45cc - 11.5cc) for gas (required)
    Electronic Speed Control 85A (required)
    Propeller / EDF 12x8 2-blade for electric or 12x6 2-blade for gas (required)
    Servos 45g metal gear standard: left aileron, right aileron, elevator, rudder - HRC6005-017
    17g metal gear standard: left flap , right flap - HRC6005-022
    Landing Gear Fixed (included)
    Required Battery 4 Cell 14.8V 5000mAh LiPo Battery (required)
    Required Radio 6+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights No
    Hinge Type CA fabric
    Material Balsa and light plywood
    Skill Level Intermediate
    Build Time 6+ Hours
