Official Nexa 1620mm J-3 Cub ARF Discussion Thread
    J-3 Cub 1620mm (63.7") Wingspan - ARF from Nexa - NXA1005-002
    The Piper J-3 Cub is a small, simple, light aircraft that was built between 1937 and 1947 by Piper Aircraft. With tandem (fore and aft) seating, it was intended for flight training but became one of the most popular and best-known light aircraft of all time. The Cub's simplicity, affordability and popularity—as well as its large production numbers, with nearly 20,000 built in the United States—invokes comparisons to the Ford Model T automobile.
    This ARF requires assembly and installation of your choice of servos and power system, and includes two piece wing with aluminum wing joiner, fiberglass cowl and operational pilot door. A large battery tray provides ample space for any size battery you require.
    Fully Covered and Detailed
    The Nexa J-3 Cub comes fully covered in a US Army "Cub Yellow" scheme.
    History Recreated
    Expansive clear cockpit panels enhance the observation characteristic of the Cub platform.
    Two Piece Wing with Aluminum Wing Joiner
    The J-3 Cub has a two piece wing with aluminum wing joiner for easy transportation.
    Fiberglass Cowling
    A fiberglass cowling arrives pre-painted and ready for your electric motor or liquid fuel engine.
    • Complete Balsa and lite-ply construction for rigidity and durability
    • Two piece wing with aluminum wing joiner for easy transport
    • Large battery tray provides ample space for any size battery you require
    • Functional pilot door and well appointed throughout
    • Fiberglass cowling for strength and durability
    • All control surfaces come out of the box pre-hinged and installed for convenience
    • Nexa J-3 Cub 1620mm (63.7") Wingspan - ARF
    • Electric motor mount
    • Wheels, spinner, hardware and decals
    Requires:Customer Note
    Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Intermediate
    BUILD TIME : 6+ Hours
    Model Scale 1/6.6
    Wingspan 1620mm / 63.7in
    Length 1250mm / 49.2in
    Weight 2700g / 95.23oz
    CG (Center of Gravity) Refer to the manual
    Power System .46 size brushless outrunner motor (required)
    Electronic Speed Control 85A (required)
    Propeller / EDF 12x8 2-blade (required)
    Servos
    • 2x 17g standard servos for ailerons - HRC6005-014
    • 2x 45g standard servos for elevator and rudder - HRC6005-015
    Landing Gear Fixed (included)
    Required Battery 4 Cell 14.8V 4000 - 5000mAh LiPo battery (required)
    Required Radio 5+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Hinge Type Nylon
    Material Balsa and light plywood
    Skill Level Intermediate
    Build Time 6+ Hours
