Official Nexa 2500mm Motorspatz Glider ARF Discussion Thread
    Motorspatz Glider 2500mm (98.4") Wingspan - ARF from Nexa - NXA1057-001
    The SF-24 Motorspatz by German designer Egon Scheibe is a motorized, single-seat, high-wing glider derived from the non-motorized Scheibe Spatz. Described as "primitive" in 1983 by Soaring Magazine, it is a notable example of self-launching sailplanes.
    The Nexa Motorspatz Glider is a electric option glider with a 2500mm wingspan, constructed primarily from balsa wood and covered with a weathered pattern. This ARF requires assembly and installation of your choice of servos and power system, and includes a large battery hatch and electric motor mount. Impress at your flying field with this unique glider!
    Spacious Battery Hatch
    The Nexa Nexa Motorspatz Glider comes equipped with a spacious battery hatch with ample room for your battery and periphreal electronics and equipment.
    Easy Servo Access
    A convenient servo access hatch is pre-installed so you will have no problem accessing the servos at any time you require.
    Fully Covered Weathered Detail
    The Nexa Motorspatz Glider comes fully covered with a realistic weathered-detail pattern and an attractive blue and white livery.
    Control Surfaces Pre-Hinged and Installed
    All control surfaces are pre-hinged and installed for your convenience.
    • All Balsa and lite-ply construction
    • Fully covered in weathered detail
    • Control surfaces pre-hinged and installed
    • Two piece wing with aluminium wing joiner
    • Big battery hatch for Electric version
    • Electric Motor mount
    • Nexa Motorspatz Glider 2500mm (98.4") Wingspan - ARF
    • Assembly instructions with stage photos
    • Electric motor mount
    • Aluminium wing joiner
    • Decals and all hardware
    Requires:
    Customer Note
    Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Intermediate
    BUILD TIME : 6+ hours
    Model Scale 1/5.5
    Wingspan 2500mm / 98.4in
    Length 1120mm / 44.9in
    Empty Weight 1350g / 47.6oz
    CG (Center of Gravity) 70mm from the leading edge of the wing's root
    Power System 950Kv or equivalent brushless outrunner motor (required)
    Electronic Speed Control 45A (required)
    Propeller / EDF 10x6 2-blade (required)
    Servos
    • 4x 17g metal gear servos for ailerons, elevator and rudder - HRC6005-022
    Landing Gear Single wheel (included)
    Required Battery 4 Cell 14.8V 2500 - 3700mAh LiPo battery (required)
    Required Radio 4+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Hinge Type Nylon Heavy Duty
    Material Balsa and light plywood
    Skill Level Intermediate
    Build Time 6+ Hours
