Official Nexa 2720mm Pilatus PC-6 Swiss ARF Discussion Thread
    Pilatus PC-6 Swiss 2720mm (107") Wingspan - ARF from Nexa - NXA1028-002
    The Pilatus PC-6 Porter is a single-engined STOL utility aircraft designed by Pilatus Aircraft of Switzerland. First flown in 1959, it has been built in both piston engine and turboprop-powered versions and was produced under license for a time by Fairchild Hiller in the United States. After around 600 deliveries in six decades, Pilatus produced the last one in early 2019.
    The Nexa Pilatus PC-6 is a electric or gas option 30cc-size civil airplane with a 2720mm wingspan, constructed primarily from balsa wood and covered with a fuel-resistant covering. This ARF requires assembly and installation of your choice of servos and power system, and includes fully functional flaps, fiberglass cowl, operational pilot and read doors and other scale details. The large battery hatch affords ample room for either electric or gas setups. Impress at your flying field with this unique civil flyer!
    Fully Covered
    The Nexa Pilatus PC-6 comes fully covered including panel line and rivet detail.
    Scale Details Throughout
    There is no shortage of scale details with this Pilatus PC-6 including functional flaps, functional doors and painted canopy.
    Fiberglass Cowling
    The cowl is made of fiberglass for both looks and durability.
    Impressively Sized
    The Pilatus PC-6 comes in at a whopping 1/6 scale (2720mm/107" wingspan) but is easy to transport with easy wing removal.
    • Complete Balsa and lite-ply construction for rigidity and durability
    • Covered from tip to tail in scale details including functional flaps, workable pilot and back seats, printed simulated panel lines and rivets
    • Fiberglass cowling for strength and durability
    • All control surfaces come out of the box pre-hinged and installed for convenience
    • Large battery hatch allows for your chosen electric or gas setup
    • Nexa Pilatus PC-6 Swiss 2720mm (107") Wingspan - ARF
    • Wheels and spinner
    • Fuel tank, hardware and decals
    Requires:Gas Requires:
    • 26-30cc gas engine
    • 18x6 gas propeller
    Customer Note
    Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
    AGE LEVEL : 14 and up
    SKILL LEVEL : Intermediate
    BUILD TIME : 7+ hours
    Model Scale 1/6
    Wingspan 2720mm / 107.0in
    Length 2000mm / 78.7in
    Empty Weight 8800g / 310.41oz
    CG (Center of Gravity) 90-95mm from the leading edge of the wing's root
    Power System 2500+ Watt Brushless Outrunner Motor for electric or .26-.30cc engine for gas (required)
    Electronic Speed Control 80+A High Voltage (required)
    Propeller / EDF 20 x 8E to 21 x 10E 2 blade electric propeller (required)
    Servos
    • 5x high voltage/torque servos for ailerons, elevator and rudder - HRC6005-019
    • 2x 45g standard servos for flaps - HRC6005-015
    Landing Gear Steel wire gear (included)
    Required Battery TWO 6 Cell 22.2V 3500 - 5000 mAh LiPo Batteries in series (required)
    Required Radio 7+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights No
    Hinge Type Nylon Heavy Duty
    Material Balsa and light plywood
    Skill Level Intermediate
    Build Time 7+ Hours
    Tiger Version:
    Buy Nexa Pilatus PC-6 Tiger 2720mm (107") Wingspan - ARF online at Motion RC. Order online with fast delivery.
