Official Skynetic 750mm P-47 Thunderbolt “Passionate Patsy” Warbird with Retracts PNP Discussion Thread
    • 8228
    P-47 Thunderbolt “Passionate Patsy” 750mm (29.5”) Wingspan Warbird with Retracts PNP from Skynetic – SKY1073-001
    The P-47 Thunderbolt is one of the most iconic American fighter aircraft of World War II. Built around the massive Pratt & Whitney R-2800 Double Wasp radial engine, the Thunderbolt was the largest and heaviest single-engine fighter of the war — a rugged, hard-hitting machine that excelled in both air-to-air combat and ground attack. Its distinctive round fuselage, wide elliptical wings, and massive four-blade propeller give the Thunderbolt an unmistakable silhouette that warbird enthusiasts recognize instantly.
    The Skynetic P-47 Thunderbolt “Passionate Patsy” brings the legendary P-47 Razorback to a compact model that punches well above its size class. Finished in authentic 310th Fighter Squadron, 58th Fighter Group markings — complete with the famous “Passionate Patsy” nose art — the model delivers serious scale credibility in a package that’s easy to transport and quick to assemble. And like its stablemate the TBM Avenger, it comes with fully electric retractable landing gear, a feature rarely found at this size.
    Built from durable lightweight EPO foam, the Skynetic P-47 delivers a low flying weight for responsive performance across a wide speed range. The carefully tuned aerodynamic design keeps the model lively and engaging in the air while remaining stable and predictable at slower speeds for smooth, confident approaches and landings. A detachable 1-piece wing simplifies transport and storage, while ball-link control connections provide accurate, rattle-free control response. A detailed cockpit with molded pilot figure, clear canopy, scale armament, and pitot details complete the package — bringing the character of a legendary warbird to life at every angle.
    Small scale. Large scale detail. The Skynetic P-47 Thunderbolt delivers the realism, features, and flight performance normally reserved for much larger warbirds.
    Small Scale. Big Thunderbolt Presence.
    The Skynetic P-47 Thunderbolt stands apart with electric retractable landing gear, a feature rarely found in warbirds of this size. Watch the aircraft transition from a confident runway stance to a clean scale profile in flight — delivering the look and presence of a much larger warbird in a compact, easy-to-fly package.
    Passionate Patsy — A Living Piece of Warbird History
    Finished in authentic 310th Fighter Squadron, 58th Fighter Group markings, this P-47 captures the look of a real combat Thunderbolt that flew missions in World War II. Fuselage code H42, bold nose art, and crisp scale graphics bring that personal history to life on the flightline and in the air.
    That Unmistakable Thunderbolt Silhouette
    Few WWII fighters are as instantly recognizable as the P-47 — the massive round cowl, wide elliptical wings, and large 4-blade propeller make it unlike anything else in the sky. This model captures all of it, at every angle, from the ground up.
    Scale Details That Earn a Second Look
    A detailed cockpit with molded pilot figure, clear canopy, scale armament details, and authentic pitot tube add another level of realism. The scale 4-blade propeller and spinner complete the unmistakable Thunderbolt character both on the ground and in flight.
    A Warbird That Loves to Fly
    Plenty of energy when you want it, smooth and forgiving when you need it. The P-47's refined aerodynamics make it as enjoyable on a relaxed cruise as it is on a fast, low pass down the flightline.
    Everything a Warbird Should Be
    Big personality, compact package. The Skynetic P-47 Thunderbolt puts one of the most beloved warbirds of World War II on the flightline in a model that's easy to transport, quick to assemble, and seriously fun to fly.
    • Electric retractable landing gear included for realistic scale operation
    • Compact 750mm P-47 Thunderbolt with impressive warbird presence in the air
    • Authentic 310th Fighter Squadron, 58th Fighter Group “Passionate Patsy” scale livery
    • Durable lightweight EPO foam construction with crisp molded surface detail
    • Aerodynamically refined design for strong performance across a wide speed range
    • Lively warbird performance while remaining stable and predictable at slower speeds
    • Detachable 1-piece wing simplifies transport and storage
    • Ball-link control connections provide smooth and precise control response
    • Factory-installed brushless power system optimized for 3S LiPo batteries
    • Designed for 3S 800–1200mAh LiPo batteries for balanced flight performance
    • Rich scale details include a molded pilot figure, clear canopy, scale armament, and pitot tube details for an authentic appearance in the air and on display
    • Scale 4-blade propeller with spinner for authentic Thunderbolt look
    • Spacious top hatch simplifies battery swaps and in-field checks
    • Factory-installed servos for quick setup and reliable operation
    • Skynetic P-47 Thunderbolt “Passionate Patsy” 750mm (29.5”) Wingspan Warbird with Retracts – PNP
    • Electric retractable landing gear with scale struts (installed)
    • Factory-installed servos with ball-link control connections
    • Factory-installed brushless motor, ESC, and scale 4-blade propeller with spinner
    • Instruction manual
    AGE LEVEL : 14 and Up
    SKILL LEVEL : Intermediate
    BUILD TIME : 30+ Minutes
    Model Scale 1/16.5 Scale
    Wingspan 750mm / 29.5in
    Length 658mm / 25.9in
    Weight 470g–490g (16.6–17.3 oz) including battery
    CG (Center of Gravity) 50–55mm as measured from the wing root leading edge aft
    Power System DST-1200 brushless motor (included)
    Electronic Speed Control 20A with JST connector (included)
    Propeller / EDF Scale 8x6 4-blade (included)
    Servos 4x 9g plastic gear servos (included)
    Landing Gear Retractable landing gear system with scale struts (included)
    Required Battery 3S 11.1V 1000-2000 mAh LiPo battery with JST connector (required)
    Required Radio 5 channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Brakes No
    Gyro No
    Hinge Type Foam & Heavy-duty CA (Rudder)
    Material EPO Foam
    Skill Level Intermediate
    Build Time 30+ Minutes
    Recommended Runway Surface Well manicured, short grass and hard surfaces
  • Beaver73
    • May 2025
    • 5
    Maiden tomorrow! From the setup, and design clearly will be nicer than the Avenger. That one is terrible.
    • Nickerz
      • Feb 2019
      • 5
      Did you get to maiden it!?
      • Beaver73
        • May 2025
        • 5
        Hi Nick. Yessir. Successful maiden, but barely. I used a 3s 1500mah, and per the manual setup the girl was veryyyyyy tail heavy. Battery all the way forward. Very quick to pull the power back and trim to get her stable. Second flight was with the 3s 2000, and she flew much better. Good speed, good control, even with the tail heavy setup. She didn’t stall and spin right away. I didn’t have a receiver with as3x or gyro, but that would have helped lol. After getting it setup properly, I do like it much better than the TMB avenger. Something abt that plane I don’t like at all. This was done with grass ops, cut relatively short. Landed and took off just fine. I’d recommend the P-47.
        • Nickerz
          • Feb 2019
          • 5
          Thanks for the update! Nice to hear you like how it flies once you got things sorted out and like you said, this is without a Gyro. The guys here... mention not needing one but it flies like a bigger plane with a gyro so I'll see what I do in the end. Btw, glad to know your bigger lipo (2000mAh) worked! I found a 2200mAh with nearly the same dimensions, just 15 grams heavier than the Admiral 1300mAh that I was thinking about using. Sounds like more weight up front can help anyway! It's also nice to hear she will take off and land in short grass! Post pics or video link if ya got them but thanks again and happy flying!
          • Foxbow
            • Jan 2021
            • 8
            So how in the world did you get the battery straps strapped down? I can’t even get my fingers in there to tighten or undo them as there is no access or room?
