Here's my suggestion..............
The stock prop on the LX F4F is 12x6x3
The stock prop on the FL Tigercat is 12x7x3
Use the standard rotation prop and hub and prop shaft from the FL Tigercat.
The prop shaft on the LX F4F I believe is the same one used on the LX B-25.
I used the LX B-25 shaft and props on my FL Tigercat using the original FL motors.
So the reversal of using an FL shaft on the LX motor should hold true for bolt pattern, that is if my assumption about the F4F is correct in the fifth sentence. ;)
.png)
