Official Nexa 1540mm Ki-61 Hein "Tony" ARF Thread
    • 8222
    Ki-61 Hein "Tony" 1540mm (60.6") Wingspan - ARF from Nexa - NXA1078-001
    The Kawasaki Ki-61 Hien, known to the Allies by the codename "Tony" was the only Imperial Japanese Army Air Force (IJAAF) fighter of World War II built around a liquid-cooled, V12 engine. That powerplant, a license-built derivative of the German DB 601, gave the Hien a sleek, low-drag nose profile unlike any other Japanese fighter of the era, with a slender, European-style silhouette that set it apart from Japan's traditionally radial-engine fighter lineup. Entering service in 1943, the Hien paired that unusual powerplant with strong speed, firepower, and structural strength, and its high-altitude performance made it one of the more capable IJAAF fighters of the war.
    The Nexa Kawasaki Ki-61 Hien 1540mm (60.6") wingspan ARF brings this distinctive fighter to the flying field finished in the striking markings of the 244th Sentai's Headquarters Chutai, based at Chofu, Tokyo in 1944–45. The scheme pairs a mottled green camouflage over the fuselage with a bold dark blue tail, a white lightning-streak, and twin command stars — one of the most recognizable and requested liveries the Hien ever wore. Built from balsa and lite-ply construction with a fiberglass cowling and included spinner, the airframe is covered and decorated at the factory to match, with pre-hinged control surfaces and a two-piece, center-joined wing that speeds up final assembly.
    Scale detail carries all the way through the model. A hand-painted pilot bust sits in the cockpit, with dummy machine gun detail, a wooden antenna mast, and a scale pitot tube rounding out the presentation. The model comes with fixed main gear and a steerable tail wheel out of the box, with VQ Models' electric retractable landing gear available as a bolt-on upgrade for pilots who want scale retracts in flight.
    Where this model really stands apart is power system flexibility. The same airframe accepts a .46–.50 2-stroke or .60–.70 4-stroke glow engine for pilots who prefer traditional glow power, or an 870-watt-class electric power system for pilots who'd rather fly electric. Either way, the Hien delivers the kind of scale look and honest, mid-size warbird flying character that's hard to find in a model this manageable to build, transport, and fly.
    Authentic Scale Covering in a Striking Scheme
    Factory-applied covering brings the 244th Sentai Headquarters Chutai livery to life, pairing mottled camouflage with a bold dark blue tail, white lightning-streak, and twin command stars for a striking presence on the flightline.
    Fine Scale Touches, Inside and Out
    A hand-painted pilot bust, dummy machine gun detail, and a wooden antenna mast bring fine scale character to the cockpit and airframe alike.
    Molded Cowl & Spinner Included
    A fiberglass cowling and spinner are included and shaped to match the Hien's sleek nose profile, ready to complete the airframe right out of the box.
    Classic WWII Performance You Can Feel
    Whether you power it with a .46–.70 glow engine or an 870-watt-class electric system, the Hien delivers the kind of honest, mid-size warbird flying character that made WWII fighters a joy to fly.
    • Distinctive Ki-61 Hien design stands out from typical warbirds on any flightline
    • Striking 244th Sentai camouflage livery delivers strong presence in the air and on the ground
    • EP/GP compatibility lets you choose electric simplicity or glow realism
    • Scale-inspired design delivers smooth, stable, and predictable flight characteristics
    • Designed for .46–.50 2-stroke, .60–.70 4-stroke, or 870-watt-class electric power for flexible performance
    • Functional scale split flaps improve low-speed control for smoother, more confident landings
    • Nexa electric retractable landing gear upgrades the standard fixed gear for a cleaner in-flight profile
    • Hand-painted pilot bust adds realism and scale presence in the cockpit
    • Dummy machine gun detail and a wooden antenna mast round out the scale character
    • Balsa and lite-ply construction delivers a rigid, durable airframe
    • Factory-applied covering provides a clean, professional finish right out of the box
    • Pre-hinged control surfaces reduce build time and simplify setup
    • Two-piece, center-joined wing with wood dihedral brace speeds up final assembly
    • Fuel tank, engine mount hardware, and servo trays included for glow builds; motor mount plate included with electric power system sets
    • Complete hardware and decal package with a photo-illustrated instruction manual
    • Nexa Kawasaki Ki-61 Hien "Tony" 1540mm (60.6") Wingspan ARF airframe with factory-applied scale covering
    • Painted cockpit with pilot figure and interior details
    • Comprehensive control linkages, hardware, and assembly accessories
    • Instruction manual
    Requires (Electric):Requires (Gas):Customer Note
    Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
    AGE LEVEL : 14 and Up
    SKILL LEVEL : Intermediate
    BUILD TIME : 8+ Hours
    Model Scale 1/7.8
    Wingspan 1540mm (60.6in)
    Length 1120mm (44.0in)
    Empty Weight Approx. 2700–2900g (6.0–6.4lbs)
    CG (Center of Gravity) 88–92mm (3.4–3.6 in) aft of the leading edge, measured at the wing center section
    Power System 670Kv or equivalent brushless outrunner motor for electric or .46 - .70 (7.45cc - 11.5cc) for gas (required)
    Electronic Speed Control 80A Brushless (electric power only, required)
    Propeller / EDF 13x12 3-blade for electric or 11x7 2-blade for gas (required)
    Servos Electric: 6 x servos (required) — 4x Hitec HS-485HB standard servos (ailerons, elevator, rudder), 2x Hitec HS-85BB micro servo (flaps)
    Gas: 7 x servos (required) — 5x Hitec HS-485HB standard servos (ailerons, elevator, rudder, throttle), 2x Hitec HS-85BB micro servo (flaps)
    Landing Gear Fixed main gear with steerable tail wheel (included); Electronic retractable gear (optional)
    Required Battery 4 Cell 14.8V 4500 - 5000mAh LiPo Battery (required)
    Required Radio 6+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights No
    Hinge Type Pre-hinged, CA-glued slot hinges
    Material Balsa and lite-ply with fiberglass cowling and spinner
    Skill Level Intermediate
    Build Time 8+ Hours
    Recommended Runway Surface Well manicured short grass and hard surfaces
