Giant Stick 1940mm (76.4") Wingspan - ARF from Nexa - NXA1077-001
The Nexa Giant Stick 1940mm (76.4") wingspan ARF is a giant-scale sport plane built for pilots who want big, confident aerobatics without the complexity of a full scale warbird. Its simple, high-wing stick-and-tube layout has been a favorite trainer-to-aerobat airframe for decades, and this version brings that proven design to giant scale with the build quality to back it up.
Built from balsa and lite-ply construction with a two-piece wing for easy transport, the airframe arrives factory-covered and ready for final assembly, with pre-hinged control surfaces and a large battery/fuel hatch for quick access. Fixed aluminum main gear and a steerable tail wheel round out a durable, field-ready setup built to handle rough strips and hard landings alike.
Where this model stands apart is power system flexibility. The same airframe accepts a 17–20cc gas engine for pilots who want giant-scale gas power, or a high-power brushless electric system for pilots who'd rather fly electric. Either way, the Giant Stick delivers the honest, predictable sport-flying character that's made stick-style airframes a mainstay on flying fields for generations.
Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
AGE LEVEL : 14 and Up
SKILL LEVEL : Intermediate
BUILD TIME : 8+ Hours
| Bold Graphics, Ready for the Field Factory-applied red and white covering with a graphic honeycomb pattern gives the Giant Stick a striking look on the flightline, with fixed aluminum main gear and a steerable tail wheel visible and ready to go. |
| Honest Sport-Flying Character Big and confident in the air, the Giant Stick's proven stick-and-tube layout delivers the predictable handling that's made this airframe style a mainstay for generations of sport pilots. |
| Giant-Scale Build Quality You Can Trust A look inside shows the balsa and lite-ply construction underneath the factory covering — a rigid, durable airframe built to back up its giant-scale size. |
| Power to Match Your Flying Style Whether you power it with a 17–20cc gas engine or a high-power brushless electric system, the Giant Stick delivers the honest, predictable sport-flying character that's made stick-style airframes a mainstay for generations. |
- Giant-scale sport design delivers big, confident aerobatics on any flying field
- EP/GP compatibility lets you choose electric simplicity or gas-powered performance
- Designed for a 17–20cc gas engine or a high-power brushless electric system for flexible performance
- Simple, proven stick-and-tube layout delivers honest, predictable flight characteristics
- Excellent first giant-scale gas model for pilots making the jump from electric power
- Two-piece wing simplifies transport and storage
- Large battery/fuel hatch speeds up battery changes and refueling
- Fixed aluminum main gear and steerable tail wheel stand up to rough strips and hard landings
- Balsa and lite-ply construction delivers a rigid, durable airframe
- Factory-applied covering provides a clean, professional finish right out of the box
- Pre-hinged control surfaces reduce build time and simplify setup
- Complete hardware package with a photo-illustrated instruction manual
- Nexa Giant Stick 1940mm (76.4") Wingspan ARF with factory-applied covering
- Fixed aluminum main gear and tail wheel hardware
- Fuel tank, engine mount hardware, and servo trays
- Comprehensive control linkages, hardware, and assembly accessories
- Instruction manual
- 5+ Channel radio - select a minimum 5 channel radio from our Radio Collection
- 5+ Channel receiver - select a minimum 5 channel receiver from our Receiver Collection
- Brushless electric motor - we recommend the Admiral GP20 6320-295Kv Brushless Outrunner Motor
- 80 Amp brushless ESC - we recommend the Castle Creations Phoenix Edge High Voltage 80A ESC
- 4x standard servos for ailerons, elevator, and rudder — we recommend the Hitec HS-645MG Standard Servo Multi-Pack
- 2x 4 Cell 14.8V 3500–5000mAh LiPo battery, wired in series for 8S — we recommend the Admiral Pro 5000mAh 4S 14.8V 60C LiPo Battery Multi-Pack
- EC5 2-to-1 series adapter (required to combine the two 4S packs into 8S) — we recommend the EC5 2-to-1 Series Adapter with 10AWG Silicone Wire
- Electric propeller - we recommend the APC 17x10 Thin Electric Propeller
- 4 Cell compatible battery charger (two packs to charge) - select a minimum 4 cell (4S) charger from our Charger Collection
- 2 stroke engine - we recommend the NGH GT17-Pro 17cc Two-Stroke Engine
- 1 servo (throttle) Hitec HS-645MG Standard Servo
- Receiver battery: 2S 2000mAh LiFe Battery - we recommend Admiral 2100mAh 2S 6.6V LiFe Battery with XT60/JR/Futaba Connectors
- Gas Propeller: 15x8 - we recommend Admiral 15x8 Gas Series Wood Propeller
BUILD TIME : 8+ Hours | Model Scale | N/A |
| Wingspan | 1940mm (76.4in) |
| Length | 1460mm (57.5in) |
| Empty Weight | Approx. 4.0–4.3kg (8.8–9.5lbs) |
| CG (Center of Gravity) | 102mm (4.0in) aft of the leading edge, measured at the wing root at the fuselage sides |
| Power System | 295Kv or equivalent brushless outrunner motor for electric, or NGH GT17-Pro 17cc (equivalent to 17–20cc) for gas (required |
| Electronic Speed Control | 80A High Voltage Brushless (electric power only, required) |
| Propeller / EDF | 17x10 for electric or 15x8 for gas (required) |
| Servos | Electric: 4 x servos (required) — 4x Hitec HS-645MG standard servos (ailerons, elevator, rudder) Gas: 5 x servos (required) — 4x Hitec HS-645MG standard servos (ailerons, elevator, rudder) + 1x Hitec HS-645MG standard servo (throttle) |
| Landing Gear | Fixed aluminum main gear with steerable tail wheel (included); no retract option available for this airframe |
| Required Battery | 2x 4 Cell 14.8V 3500–5000mAh LiPo, wired in series for 8S (required) |
| Required Radio | 5+ Channel (required) |
| Ailerons | Yes |
| Elevator | Yes |
| Rudder | Yes |
| Flaps | No |
| Lights | No |
| Hinge Type | Pre-hinged, CA-glued slot hinges |
| Material | Balsa and lite-ply |
| Skill Level | Intermediate |
| Build Time | 8+ Hours |
| Recommended Runway Surface | Paved or well-manicured grass fields |
