Are the control surface throws for a V7 P-51 Mustang correct in the manual? Mine do not have that much travel, especially the elevator. I don't see how the elevator could travel 1.6" as stated in the manual. Which hole should the clevis be in for each control surface.
P-51 Mustang Control Surface Throws
Re: P-51 Mustang Control Surface Throws
Did you get help with this? I was watching Pete do a build review and he said you had to move the elevator back and forth quite a bit to loosen up the foam joint before assembly.
Also, have you considered cutting and using CA hinges or running 2 control rods off the elevator servo?
