I finally broke down and purchased a V8 Mustang from ForceRC. They had the gunfighter schemed mustang on sell for quite awhile and they put a August sell code out so I got 30 bucks off the sell price. Anyway who cares about that. This is the problem. Now I emailed forcerc and will try to get with them tomorrow to figure it out, but I thought i would see what anyone here thinks. The right wing is dead electrically speaking (pilot cockpit view right). List of my trouble shooting
1. Plugged the wing connector in to both ports on board, tried them one at a time in different ports etc.
2. Had brand new board and wing connectors. So, swapped out wing connector that did not work. Swapped our board. That did not work.
3. Tried different receiver, reset radio, re binded, none of that worked.
4.Disconnected aileron from wing connector. Plugged aileron directly into a receiver that was powered with a receiver pack. It worked.
5. Reset radio channel to default, re binded, tried different channels, a different receiver, still no joy.
When I say dead, I mean no aileron, flap, light or gear. I mean it is electrically dead.
Now at a glance you would thing oh its the connection board or wing connector. But I had a brand new board and wing connectors and swapped them out and still had no result. So, I am thinking that having two bad boards or three bad wing connectors is probably not the issue either. Actually the board was already proven to be good by virtue of plugging the wing connectors in to different ports with same result.
Could a ESC cause this? Its the only thing i did not do anything with
My equipment is
Spektrum DX9 radio
Spektrum DSMX ar7010 with satellite
Speltrum AR600 sport receiver(used it for trouble shooting and to verify if it was the 7010 receiver. Same result so I am thinking it was not the receiver)
My equipment is
Spektrum DX9 radio
